RedFK8
If I had extra parts I would just make them for free for all of you and just ship them out by request. It’s not too bad making them I can give you the parts list and tell you how to make them. The oem female pins are super tiny on the usdm plug. I originally was just going to heat shrink insulation over some pins and just plug them in there with the h11 female pig tail on the other end. Then heat shrink the plug to hold everything together lol. Splicing directly into the oem harness would be the best method as jumper harness is another possible point for resistance and corrosion at each plug if not sealed correctly. If you are going to go the usdm socket to h11 conversion route the usdm side marker sockets are too big to plug into the usdm fog light plugs. I reused the JDM ones that came with my jdm clear side markers since they were too small for the usdm side marker plug and they almost fit perfectly into the fog light plug.@RedFK8 would you be willing to sell a few of those conversion harness for us lazy folks?
