Ktuner v2 restart on ignition? & knock questions
kcvpr
Casey
2020 Civic Hatchback Sport
Is there an option to have the v2 restart after turning the ignition back on instead of having unplug it and the reconnect constantly? I think I have auto off turned on already.
Also, should I be worried if I’m getting like 30 knocks right when I start the engine when it’s cold? I also always seem to get 1-2 knocks when I’m shifting in the lower gears no matter what I do. Sometimes it will also randomly knock 1-2 times every minute or two if I’ve been idling for a little while while eating lunch or something.
KTuner
J.R.
Chandler, Arizona
www.KTuner.com
2017 Si
If you have a newer year vehicle, it's not currently turning on with key on, and your firmware is up to date there's an option called CAN Gateway on the main menu. Choose yes.
Hundreds in a short period might signify an issue.
kcvpr
Casey
Yeah I have a 2020. What does the “can gateway” do?
so to clarify, 30 or so knocks in the first 10-15 seconds after startup isn’t abnormal. And 1-2 knocks during shifting isn’t enough to do damage.
Linszter
TunerView Developer
Peter
Hungary
2003 Accord K24, 2005 Civic K20 VSA
