KTuner V1.2 Released!
Status
Not open for further replies.
ddood
Australia
Honda Civic 2016 VTI-LX
i only have a macbook pro for a computer. will i be unable to flash unless i can find a PC?
Just install Windows on your mac. Here's a guide I found:
https://www.windowscentral.com/how-install-windows-10-macbook
imccly89
Maryland
2017 Civic Hatchback Sport 6MT WOP
If you don't need the real-tuime display of the V2 unit, the V1.2 with the TunerView Android app solves the issue of needing to flash without a laptop present. It'd be your choice not to take advantage of that tech, in which case a laptop is required.
Just to confirm, you can lock the V1.2 to the car even without a laptop, correct? So if you have a Windows desktop, Android phone, and KTuner V1.2 you'll be good to go?
No that's not correct. At this time, the V1.2 still needs a laptop to lock and unlock. I also have the same setup as you... desktop, Android phone as well as the Tunerview app but V1.2 is a no go for me.
Ktuner is trying to find a solution though. I may wind up going with the V2 or carb Flashpro instead.
imccly89
Maryland
Okay, thanks, I wasn't sure on that. If I used an old Windows laptop for the initial ECU lock, could I then run the KTuner software on my main desktop? Or would the KTuner license only work on that laptop?
dallasjhawk
Arlington, TX
2016 Civic EX-T, 2004 Acura TSX
nope, you could load it on the old laptop, then download the software on the desktop and be fine. I have ktuner software on 2 computers no issues.
MavicTB
Terry
Dallas
18 Civic Si Sedan Aegean Blue
I know its an expense but you can get a windows based laptop for 200 or less... specially if you get a used one. I dont see the big deal here. :shrug:
imccly89
Maryland
I have one...I just wanted to avoid bringing it out of the closet every time there's a KTuner update.
dallasjhawk
Arlington, TX
So use the laptop once to lock the ktuner then use the desktop to do tunes and updates. You wont need the laptop after initial setup
ddood
Australia
So the V1.2 unit can be powered and read while just being connected to the USB cable?
CivicXander
17 Civic hatchback Sport 6MT Rallye Red
i wish we could check our CEL with just the tunerview app
varge
George
Greece
Civic 1.5T 4D Elegance EUDM
Not sure if it's been mentioned elsewhere but if it was possible to run TunerView in Android Auto it would be absolutely fantastic!
Locking and unlocking from TunerView would make the V1.2 perfect for a lot of people, myself included.
Status
