KTuner V1.2 Released!
Status
Not open for further replies.
RamrodSi
Josh
Johnson City, TN
2017 Honda Civic Si coupe
Ok - I was just going off of the default screen that shows up in the program as it is currently setup. I'll look for that next time. Will there be engine sounds or actions that indicate that something is wrong with a tune? Or is this something that's imperceptible?
I think I recall Vit saying knock is hard to guage in these motors. As long as you stay with the base tunes/Vit Stage 1 you'll be ok. They are still pretty conservative.
Chief 08
David
Germany
2017 Civic Si coupe
You did not check it out very well.
Oh really? The V1.2 is listed separately and makes no mention of a vit tune being included. This is a screen shot of the V1.2 description, show me where I missed the part about the Vit tune. The website must be wrong because the only one that includes the Vit tune is V1, or V2.
tapakidney
Northern VA
2017 ABM Civic Si Coupe
All new sales of the V1 are a 1.2. I had the same concern and confirmed it before placing my order.
https://vittuned.com/ktuner-flash-civic-si-combo-stage-1.html
Chief 08
David
Germany
2017 Civic Si coupe
Thank you. So they're both the same? Its confusing becaus it' listed twice., one with, one without.
KTuner
J.R.
Chandler, Arizona
www.KTuner.com
2017 Si
Of course. One option is listed as a Stage 1 combo for the CivicX Si specifically. The other one with just the unit is for everything else (Non-Si etc).
Chief 08
David
Germany
2017 Civic Si coupe
Great, thanks again.
SI Willy
Will
2017 black Civic SI coupe, 1996 black Civic ex coupe, 1994 Toyota pickup
I'm ready to pull the trigger on the v1.2 from vittuned but have a question about the tuner view app. Can I use a dedicated android phone with no cellular connection?
RamrodSi
Josh
Johnson City, TN
Yes, the app requires no data except to update, which is quite frequent.
SI Willy
Will
tapakidney
Northern VA
Another noobish question - I can't seem to find a straightforward answer. What is the theoretical risk of running a higher than stock PSI? Reducing the life of just the turbocharger? Or reducing the life of the entire engine? Or something else?
RamrodSi
Josh
Johnson City, TN
I think it's too early to tell if there will be any long term effects. But I honestly think even with higher boost pressures, these little motors are more efficient than stock tunes.
tapakidney
Northern VA
Even if it's too early to tell definitively on this particular engine, isn't there info to be gained from looking at the results of previously overboosted turbos? Just trying to figure out what my worst case scenario is for messing around with this stuff.
3925blue
Texas
2018 Honda Civic Si sedan
Well, actually, "worst-case scenario" literally is a blown engine. If you are not comfortable in a vehicle with a modified powertrain, then don't do it. However, Many people on many factory- turbo vehicles run more boost, advanced timing, and generally more power on fairly original engines. If you want the best of both world, a more powerful car and peace-of-mind for reliability, then you'll need to have experienced professionals help you. That's not meant to sound demeaning, just very matter-of-fact. Don't do an off-the-shelf "starter tune" - get someone like Vit to run a custom tune and tell him your concerns. You'll be taken care of.
Status
