Joe1986
What happens if you enable the advance vsa with the most aggressive settings and completely disable the vsa pedal dance? Would the advance vsa still take effect?Hello Fellow Enthusiasts!
It is with great pleasure that we bring you a release full of progress for the 10th gen platform! We have been very busy and very quiet with everything happening here, but there is so much in the works!
This update is live on the website and available now!
For the Si (All 17-19):
New P2565 Wastegate Disable For Use With Aftermarket Turbo Kits Like The PRL Big Turbo Kit and MAPerformance Kits. If you used the previous option, uncheck it, then check the new one instead. Cleaner full disable and keeps Sport mode fully operational. The old disable is still available in the event something else arises.
Advanced VSA Control (If you know someone with a 2.0T Accord, this is available for them too)
Tired of the VSA system overreacting? We've had this option in development for some time and it's a great tie in to the factory VSA system. Maintaining some level of throttle intervention, we have built on the ECU's control of ignition during loss of traction. Simply enable the Advanced VSA feature in Quick Enables and then select your level of balance between ignition and throttle for the Advanced VSA Control Strategy under Quick Adjustments.
Please note in a situation that calls for it, like if TPMS says your tires aren't equal or you're on a spare, Advanced VSA can be disabled by enabling Cruise Main on the dash.
Advanced VSA Control will make its way to Non-Si platforms soon, as we may change or add options based on the feedback for the Si platform.
Link to Advanced VSA help page: http://ktuner.com/KTunerHelp/advanced_vsa_control_strategy.htm
For the Non-Si:
New P2565 Wastegate Disable For Use With Aftermarket Turbo Kits Like The PRL Big Turbo Kit and MAPerformance Kits. If you used the previous option, uncheck it, then check the new one instead. Cleaner full disable.
Available Today For These ECU Models, available soon for others:
Hatchback Models
- 5AA-A0x
- 5AA-A57
- 5AA-L58
- 5AA-A67
- 5AA-L68
- 5AA-C0x
- 5AA-C57
- 5AA-C67
- 5AA-K0x
- 5AA-K1x
- 5AA-K2x
- 5AA-X0x
- 5AN-95x
- 5AN-A0x
- 5AN-A1x
- 5AN-A5x
- 5AN-B5x
- 5AN-L5x
- 5AN-A6x
- 5AN-L6x
- 5AN-C0x
- 5AN-C1x
- 5AN-C5x
- 5AN-K6x
Multi-Map Switching (CVT and MT) And Adjustable Launch Control (MT Only) Added To These Additional ECUs:
- 5AA-A1x
- 5AA-A7x
- 5AA-A8x
- 5AA-C1x
- 5AA-C8x
- 5AJ-A5x
- 5AJ-L5x
- 5AJ-L6x
- 5AJ-L7x
