Ktuner on 2019 Type R, A21 ECU max boost?
Learn2turn
Christopher
Rio Rancho NM
'79 Toyota Longbed PU, '95 (Drift Toy) Miata, '05 Tuned Gran Prix White S2000, '19 Championship White C-Type R
I am asking anyone running Ktuner on the 2019 Type R, A21 ECU... what is the max boost you are seeing now compared to the max boost you were seeing before Ktuner?
If you ALSO added bolt ons that is fine, just please list them.
Again to be clear, I am looking for the relative boost increase in psi readout on the dash.
WHAY DO I ASK?: My friend with Hondata is seeing 22psi and KTuner is getting me 17psi, so before I switch I'd like some feedback from fellow A21 ECU flashers using KTuner.
Thank you my Friends :)
Learn2turn
Learn2turn
Christopher
Rio Rancho NM
OK, no wonder there are not enough complaints to get KTuner to help.
Tonight...
I drove around with stage 1 and had 17psi.
then came home and...
I reflashed back to stock, tested again and had 16psi.
came back home and...
flashed to the stage 1 W/DOWNPIPE to experiment, tested again and had 17psi
came back home again and...
flashed back to stage 1, tested again and had 17psi.
UGH! :(
veilside84
New York
2017 Civic Type-R
The ECU targets torque not boost. Your wasting time flashing trying to figure it out. Temperature, elevation, and other factors change the amount of boost your car needs to target the amount of torque.
Learn2turn
Learn2turn
Christopher
Rio Rancho NM
I understand that but please realize you are paying for MORE torque and it is not there without a marked improvement of boost pressure. I have read the Ktuner explanation and have sent several emails and their responses refer to what you say above.
Are you trying to say the car is making all the improvement it can, at 17psi?
Linszter
TunerView Developer
Peter
Hungary
2003 Accord K24, 2005 Civic K20 VSA
You don’t always need more boost to achieve torque target.
Learn2turn
Learn2turn
Christopher
Rio Rancho NM
Sure. Don't expect the car to be accelerating any faster either.
seselectronics
CivicX Basic Sponsor
Daniel
Civic type R
In witch gear are you testing? remember mostly throttle torque map are de-tuned on 1, 2, and some cases 3 gear, I would test on 4 gear to be sure, what is the ambiance temperature and humidity?
boosted180sx
torrance, ca
2017 CTR, 2016 ILX
you can gain more power by adding ignition timing, cam angles, etc instead of just adding boost.
Also i don't think it's fair to compare hondatas boost number to ktuner boost number because i doubt they are using the same map.
best bet is to contact Ktuner and email them a datalog of the pull and see if they see any abnormalities. I personally don't have experience with them but people have said they have good customer service.
Night Fury
Chicago
Black Type R
I don’t want to send an advice that could sound as an expensive proposition, BUT: would be able to dyno tune your car before you do the switch? The results will clear doubts of what's going on.
