carsonpecore
- Carson
- Nov 25, 2022
- 38
- 118
- 34
- Tampa
- Civic 1.5T
Hey guys. Anyone know of a 3D print model for a Ktuner v2 mount? Thanks
Thanks for the great reply with a ton of info. Definitely making a purchase later tonightTwo Step Performance carries two...
https://www.twostepperformance.com/products/new-ktuner-v2-above-stereo-mount-for-2016-honda-civic
https://www.twostepperformance.com/products/new-ktuner-v2-center-console-mount-for-2016-honda-civic
Niku Motors has...
https://www.nikumotors.com/products/lhd-honda-civic-16-21-10th-generation-in-dash-phone-mount
https://www.nikumotors.com/products/dual-t-slot-adapter-mount-kit
UPDATE: Apparently they are now 15% off... pretty sure I paid full price Dec 30... ffs.
You can also just get their LHD (*or RHD) bracket and then mount it with something supporting the AMPS pattern like the QuadLock Flat Rectangle base [ You will need to supply your own nuts and bolts... I like ProBolt USA ]
https://www.quadlockcase.com/collections/quad-lock-360/products/quad-lock-360-base-flat-rectangle
QuadLock
Or you can go 100% QuadLock ...
Get either the original mechanical twist lock mount, or the new Mag mount
https://www.quadlockcase.com/collections/shop-universal/products/universal-adapter
Then pair it with their 360 adapters to suit your car
The Mag stuff is fricking awesome, I cannot recommend highly enough.
The phone cases are really good too, and the Mag phone charging is super solid.
That said the KTuner is HEAVY...
I am mounting mine in the Center Console... not sure I would want it hanging out in space.
I will install mine this weekend and hopefully get some miles on it by Monday night.
PS. Unrelated
If you are shopping QuadLock, do yourself a favour and get their Wireless CarPlay adapter, it is really slick. No Engrish web interfaces... It also has a pass-through port if you want to plug your Phone in the other side.
https://www.quadlockcase.com/collec...reless-carplay-adaptor?variant=42203608514731
The Charging Pad is also excellent, really solid grip with the Mag cases... I would not hesitate to install this into the Civic center console cubby, your phone is not flying off unless you go off a cliff. However I just use it on a desk at home...
https://www.quadlockcase.com/collec...-wireless-charging-pad?variant=42042649313451
Good find! That Ktuner mount looks just like my phone mount, which is arguably the best phone mount I've ever used.Two Step Performance carries two...
The quadlock products look great and the pricing is pretty good. Are you drilling directly into your dash with the rectangle base?Two Step Performance carries two...
Niku Motors has...
QuadLock
PS. Unrelated
If you get the Niku Motors mount, then that is a metal bracket that just screws in behind your Climate Controls (*using the existing screw & screwhole) ... then you can then mount the rectangular base to that (Reminder: you will need some M5 countersunk bolts and nuts to do so...)The quadlock products look great and the pricing is pretty good. Are you drilling directly into your dash with the rectangle base?
Thanks for everything. Im thinking of running the Niku Mount, with the Quadlock square base, finished with the universal adapter. Lmk if there’s any problems with this plan … now I’m seeing that I don’t have a connection between the universal adapter (or universal adapter) and the square base. Or am I completely off the mark and the adapter fits onto the square base? Sorry for all the questionsPS.
Pretty sure that I bought nearly every part that QuadLock makes so if you have any specific questions about any part just hit me up... and I have no affiliation or sponsorship BS with them, btw.
I do recommend getting a third party cable with their 360 Mag Charging head.
It accepts USB-C but they cables they provide are (1) pretty short and (2) not the most flexible/pliable... their cable comes all folded over and twist-tied and so has lots of kinks, you are better off using a nice Anker cable or other good cable off Amazon. I got a generic one with a 90 degree connector that works really well...
I am still waiting on my Niku mount and my nuts and bolts, so I can't swear to fitment but here's my thoughts on your potential order:Thanks for everything. Im thinking of running the Niku Mount, with the Quadlock square base, finished with the universal adapter. Lmk if there’s any problems with this plan … now I’m seeing that I don’t have a connection between the universal adapter (or universal adapter) and the square base. Or am I completely off the mark and the adapter fits onto the square base? Sorry for all the questions
Titanium Countersunk Bolt M5x(0.80mm)x15mm (PTiColor: Titanium Black) | TICS515BK | 4 | $8.16 USD | $32.64 USD |
Aluminum Nylock Nut M5x(0.80mm) (PTiColor: Black) | LNYN5BK | 4 | $1.26 USD | $5.04 USD |
Aluminum Dome Nut M5x(0.80mm) (DIN1587) (PTiColor: Black) | LDOMENUT5BK | 4 | $1.26 USD | $5.04 USD |
Aluminum Drilled Washer M5 (10mm O/D) (PTiColor: Black) | LWAD5BK | 4 | $1.32 USD | $5.28 USD |
Aluminum Washer M5 (10mm O/D) (PTiColor: Black) | LWA5BK | 4 | $0.99 USD | $3.96 USD |
I’m guessing this is going to take a little trial and error. I’ll let you know how it turns out. Thanks!I am still waiting on my Niku mount and my nuts and bolts, so I can't swear to fitment but here's my thoughts on your potential order:
Niku mount: OK
You may want to see their FAQ page if you missed it
https://docs.google.com/document/d/...PguF_vXdbak8b28bR93B_PLX2W2G3lPdY7gPPnmhX/pub
Note that you might want to add their Dual T-Slot Mount Adapter just in case, it is an extra $13..
They charged me $20 shipping, so I would not be inclined to go BACK and order that part later.
if you think you will never use it then don't bother... I forget to pick one up at the same time.
https://www.nikumotors.com/products/dual-t-slot-adapter-mount-kit?variant=39793079910609
Quad Lock square base: OK
Quad Lock universal adapter: TBD
As long as you know what you are getting: QL make two adapters, one is the original plastic mechanical twist-lock that has no chance of detaching. The other one is the MAG Univeral Adapter. This uses strong magnets and utilizes the shape of the Quad Lock mount to provide extra support, but there is no twist-lock on it. Now I haven't taken my car off-road or ramped any railway tracks, but the magnet seemed pretty strong for the KTuner.
Original on the left, MAG on the right:
In your PM you suggested you were going to get the Lever Head mount:
I have this style on my bicycle... where obviously you stand a much greater chance of accidentally knocking off your phone and smashing it on the road. I would not choose the Lever Head for the car, I don't think you need this level of security and I am not sure you could reach the lever (easily) behind the KTuner. But interesting idea, myab its a good one.
I would choose either:
original twist mechanism
Top Cap
Wireless Charging Head
OR
MAG Head
MAG wireless charging head
My suggestion would be to get one of the Wireless Heads, and choose which attachment mechanism you prefer - the twist or the magnets. Unfortunately they are expensive, but... my thinking is that you can always unplug the USB-C cable from the back and then it looks exactly the same as the non-wireless one. The dimensions are the same iirc. But if you do want to use the charging cable, then you can always slap your phone on it, when your KTuner is not in the car. (Assuming your phone has wireless charging etc, and you use a QL MAG case on it...)
One thing I am not sure of is the angle of the Niku mount... like will we need an angle adapter to make the device face the driver properly? TBD... you can check their Instagram:
https://www.instagram.com/nikumotors/
Reminder that you need nuts and bolts to attach anything to do the Niku mount, as I don't think they supply anything, and neither does QL.
This was my ProBolt USA order... you may have cheaper options available closer to home
4 bolts,
2 different types of nuts
some washers just in case.
(PTiColor: Titanium Black)TICS515BK 4 $8.16 USD $32.64 USD
(PTiColor: Black)LNYN5BK 4 $1.26 USD $5.04 USD
(PTiColor: Black)LDOMENUT5BK 4 $1.26 USD $5.04 USD
(PTiColor: Black)LWAD5BK 4 $1.32 USD $5.28 USD
(PTiColor: Black)LWA5BK 4 $0.99 USD $3.96 USD
The Niku is 18 gauge steel ... which the internet tells me is 1.2 mm thick.
The QL base is 6mm thick.
Based on the specs that QL provide, I ordered a 15mm countersunk screw, where the threads are 12mm long (so the head is 3mm) I am hoping it is a good fit...
i.e.
3mm countersunk head
3mm rest of the base
1.2mm through the Niku mount
that should leave me 8mm out the backside,
and the nuts I ordered are 5mm tall for the open nuts and 8mm tall for the acorn nuts
and washers just in case
TBD!
PS. Image from Niku IG if you don't have it
Where did you get the 90 degree cable for your unit? It looks like it's for the new model with the plastic tip.Ok I just took a run with my KTuner on a QL Wireless MAG mount...
SOLID
Setup
KTuner v2
QL Universal MAG adapter
QL Knuckle adapter
QL Adhesive Mount
so in terms of connections:
Ktuner
--> (adhesive to ) Universal MAG adapter
--> (magnet ...) Wireless MAG mount
--> (screwed to) Knuckle Adapter
--> (screwed to) Adhesive mount
--> (adhesive to) plastic/rubber console cubby surface
combined with an Amazon sourced 90 degree USB-C to USB-C cable into a Mophie dual USB-C 40W PD car charger...
I hit some railroad tracks, and a lot of crap roads, potholes and the KTuner didn't even budge.
Now I should point out that the Ktuner is at an angle, and therefore some of that weight is driving down into the QL mount which must take some of the burden off the magnets.
Anyway, I can also slap my phone on there to charge, the only annoying thing is most apps don't support a horizontal mode...
I still plan to setup the Niku mount described, but I will probably use that for my phone and the center cubby for the KTuner when I have it in the car.
I had difficulty figuring out which QL bits to make it work in the cubby. It really depends on where on the KTuner you mount the Universal bracket, I installed mine nearer the top edge of the KTuner. Regardless of which part I tried, I wasn't having much luck getting the KTuner deeper into the cubby... there ends up being too much depth off the back of the KTuner (due the various mount pieces)
Below, the reason I can set it up like this is that I have the Acuity (short) shifter... if you had the stock shifter, I think you would be banging your hand into the KTuner. Maybe if you had the knob set high, like drift king style...
Sorry for the dust, makes me look like an animal!!!
Exactly it is the new KTuner v2 model with the Firewire IEEE1394 6-pin connection instead of that lame Samsung phone connector.Where did you get the 90 degree cable for your unit? It looks like it's for the new model with the plastic tip.
