Vincentbrown65
- Vince
- Nov 19, 2017
- 12
- 224
- 92
- Everett, WA
- 2018 Honda Civic Type R
What about a full PRL bolt-on with E85 fuel tune? That would be primo!
The blow off valve is louder because you are building more boost at part throttle now. I feel like they overdid the power at light throttle (stage 1.1). I like to choose when I want to go fast not the car to choose for me. Anybody else feel the throttle mapping is too aggressive? I do appreciate the boost in power at the higher rpms though if there truly are some.Just switched over to Ktuner from JB4 for my CTR after having fuel pressure issues. Started with the stage 0.. noticeable gain, but very mild. Stage 1, SOLID low to mid range punch just as described. I had a few email exchanges with Ktuner and he mentioned stage 1.1 which I completely overlooked. Went ahead and flashed that and WOW. I am sold! Smooth power delivery and ever so slightly stronger than the stage 1. I also feel it holds the power better to redline. My car is stock aside from a drop in filter. Even partial throttle the car is very eager to get going. I noticed that the "diverter valve?" is much louder when getting on and off the boost. I can't wait until temps drop as its 90 degrees right now in south florida. Second gear absolutely has traction issues now and third just goes!
Thank you @KTuner and DRobb for an awesome product! 10/10
I know what you mean, though it doesnt really bother me. You could always put it in comfort mode so the throttle response is less aggressive. It would also be cool if @KTuner did a multi level stage 1.1. Maybe you can copy and paste the map over to the multi tune? Or see if ktuner can do this for us.The blow off valve is louder because you are building more boost at part throttle now. I feel like they overdid the power at light throttle (stage 1.1). I like to choose when I want to go fast not the car to choose for me. Anybody else feel the throttle mapping is too aggressive? I do appreciate the boost in power at the higher rpms though if there truly are some.
I changed all of the throttle maps on the 1.1 tune to be the same as the stage 1 up to 70% throttle. I would just run the stage 1 tune but they are claiming an increase in horsepower throughout the whole range with the 1.1 and high rpm horsepower is what I'm really after.I know what you mean, though it doesnt really bother me. You could always put it in comfort mode so the throttle response is less aggressive. It would also be cool if @KTuner did a multi level stage 1.1. Maybe you can copy and paste the map over to the multi tune? Or see if ktuner can do this for us.
I haven’t but if you try and have success let me knowHas anyone added ignition timing to the tunes with success? I run 93 octane exclusively and was wondering if I could get away with adding like 2 degrees of timing from 5k to 7k to get some more horsepower.
The basemaps do have some headroom on ignition on most cars. If they didn't nobody would get a custom tuneHas anyone added ignition timing to the tunes with success? I run 93 octane exclusively and was wondering if I could get away with adding like 2 degrees of timing from 5k to 7k to get some more horsepower.
Anything else in the works you can tell us about? or just give us a winkThis is in the works!
What about a non-multi level FBO tune?This is in the works!
