KTuner Extended Testing And Tune Results
CWTypeR
Georgia
2018 CW Civic Type R # 20866 and a 2009 Acura TSX for the daily grind....
what is the “full set”? Intake, IC, FP/DP, big turbo kit?
Full set would be HVI Intake, IC, Downpipe, Frontpipe (although this could vary depending on your exhaust application, i.e some come with their own FP) and Titanium Inlet Pipe......
OrchidFc3
Holly
New Brunswick Canada
2017 Civic Type R, 1996 ITR, 1992 SI
I don't think you need "big turbo" to run the full PRL tune. Mine runs fine with that tune and I do not have a turbo upgrade but have the other bolt ons.
Maxv7
Maxime
Saint-jerome
Civic type r 2018
You're caught in the middle of 1.1 and PRL Bolt-ons since you don't have the DP/FP combo.
I have a cold air, front pipe, catless down pipe, wich tune should i take between stage 1 with down pipe or stage 1.1 or prl tune ? Thx
KTuner
KTuner
J.R.
Chandler, Arizona
www.KTuner.com
2017 Si
Either will likely run OK, as long as the intake isn't throwing fueling off, but neither will be perfect for your setup. Custom tuning is always an option.
Maxv7
Maxime
Saint-jerome
Civic type r 2018
Are you offer costom tune for my setup?
Caestus
Jeremiah
Miami Florida
19 Civic Type R
You would need to reach out to a tuner...
I highly recommend Derek Robinson at IMW.
Derf in South Florida is money. He tuned me and I am at 382/384 with a stock exhaust.
FK8REY
Rey
Winter Garden, FL
2019 Civic Type R
nice, but the stage1 doted line isnt the same has the previous one? why
stage1 vs prl map
It looks like the PRL Full Bolt on map is capping out @ approx. 360whp. I see a lot of Drob’s custom tunes with FBO falling between 375-385. Is a full Stage 2 still in the works?
KTuner
KTuner
J.R.
Chandler, Arizona
www.KTuner.com
2017 Si
Custom tuning can always produce additional gains.
A stage 2 will be something that comes along with fuel system upgrades.
FK8REY
Rey
Winter Garden, FL
2019 Civic Type R
Makes sense! Thanks
17CivicTypeR_Brian
York PA USA
What was the problem last year? You never said...
Oh shoot. I thought I did...maybe I made a separate thread about it? IDK my bad.
Turned out to be a bad coil. Coil #4 got wet down in the spark plug tube and went bad. Warranty replaced.
I feel like I need to check them after I wash the car. I'm not driving every day and the car is definitely not running as smoothly as it could.
remc86007
Ryan
Jacksonville, FL
2018 Civic Type R
^ since your post last year I make a point to run or drive the car long enough to evaporate all the water in the engine compartment after every wash. I typically just run the car and AC while I'm inside cleaning the interior.
bbeem
Ben
Iowa
Ahh, vented hood problems. Makes sense. Thanks for the update.
