number9
- #16
How do I confirm the unit is plugged in?The message about high powered USB port is a WARNING. It's not checking to see if you have one or if the unit is plugged into the vehicle. If it is, and has adequate power, you should update the firmware.
Is the proper procedure to lock the unit first, then update, or update then lock the unit?The message stating the unit isn't yet locked to an ECU means the unit should indeed be unlocked and ready for usage once you do.
Thanks for your help.
