Ktuner Civic RS CVT 1.5 Turbo 0-200
sleepingawake
Sleeping
Texas
Honda Civic RS
My car is stock except K&N Drop In Fılter and Ktuner 21PSI Base Map.
Lots of skids because of my tyres are 40.000km.
Drake
Honda Civic Si
Hold on, you're on the fuel economy gauge, correct? Why does it say your fuel economy goes up while accelerating?
samt2497
Panama
CivicX HB EX
On full stop, you're wasting gas but not moving.
After he accelerates the car is using gas but moving so the car will calculate so x gas = y kms
Drake
Honda Civic Si
Are referring to the numbers or the sliding scale? I was looking at the scale, which in NA civics goes right when you are getting good mpgs, and slides left when you are not. Dunno if the euro civics are showing different info, though
samt2497
Panama
CivicX HB EX
I got a 1.5T (not RS EX-T Hatchback) does the same, however I only get 300 km per gas tank.
I would like to tune mine, but I fear for the CVT.
The CVT is absolutely fine on a base tune. It's when folks bump up the torque down low or attempt to launch that things go south.
samt2497
Panama
CivicX HB EX
Don't want to hijack the thread but, what options would be safe using ktuner? v2 is worth it?
sleepingawake
sleepingawake
Sleeping
Texas
Honda Civic RS
I had just bought fuel, and it was about 5.0lt/100km before the first try, after the second try it was raising very fast to 7.7.
Euro Civics show LT/100km.
sleepingawake
sleepingawake
Sleeping
Texas
Honda Civic RS
That is too low, i guess you ride very hard. I have 700-750 km range per tank.
Cvt should have more limits than the factory settings.
sleepingawake
sleepingawake
Sleeping
Texas
Honda Civic RS
My stock 0-100km was 8.1 seconds. Now even with skid it makes 7. Without skid it should have 6.5 easily. Also engine is much more alive.
Drake
Honda Civic Si
Ohh so it's like the inverse of mpgs, very interesting!
