Christianjwong
- Christian
- Aug 29, 2019
- 19
- 357
- 101
- Oregon
- 2019 honda civic hatchback sport
Thanks brother, I've heard somewhere there is winter gas and it's not as good is that true?Oh man, old thread.
This has been discussed 100's of times. Anything over 1 would be concerning. But you need to put that in perspective. Even hitting 1 doesn't 100% mean you have a mechanical issue.
For example, you may see that with a really bad batch of gas after multiple pulls. Think of knock control not just as something there protecting your engine but as a reflection of your gas quality.
Ideal on KTuner is .49 and .54 on Hondata.
Even with good gas, knock control will rise up depending on environmetal factors. For example, look at it the next time you climb a long, steep hill. It will rise. It might be higher in hot weather. But the biggest culprit is using low quality, low octane gas on a tune that demands high quality, high octane.
Now let's say someone uses high quality 93 and it's a good batch of gas. Under those circumstances, you probably shouldn't be seeing really high numbers like .8 and above.
One other point. Many tuning newbies panic if they see something like .77 on the screen. But remember, that's the ECU doing it's job. It's sensing something (bad gas, load, high temps etc.) and pulls back on timing to protect your engine. So in that way, it's a good thing.
