I only just now installed TunerView Lite and such.I've asked about this a lot and my understanding is that you should consider Hondatas .54 and Ktuner's .49 as equivalent. Knock control is almost better looked at as a trending value, rather than it's value at any given time. For example, 0.60 is not necessarily a bad number, but if you see it go from 0.49 to 0.60 (or similar) under light throttle conditions, you probably have a problem.
91 octane is likely your issue. Splash in a gallon of E85 and fill the remainder up with 91 octane and see how it behaves then.I only just now installed TunerView Lite and such.
I was trying to hit 22 PSI on the Phearable tune just a second ago when I was at 0.49 knock control, and it was only hitting 18 PSI. My TunerView eventually "froze" since it lost connection, and when I reconnected the knock control was at 0.64.
I tried to drive light the rest of the way, but couldn't get it back down. I'm reading above this post that I should have hit lighter boosts for longer maybe, but I wasn't aware of the fact.
Anyway, I only have 91 octane and it was about 91 degrees outside as well, go figure (perhaps those two factors are also why I couldn't hit 22 PSI). It never did go down again after driving lightly for ten more minutes, but I'm just wondering if what I was doing was safe or not? Or should I consider something bad is going on under the hood?
Thanks.
You have for sure problems with the MAF scaling.I’m running 93 exclusively. I’ve never had problems with knock control until the catless downpipe install
Major oof, what should I do?You have for sure problems with the MAF scaling.
Sounds good, I'll do that todayDo some data logs in highway cruising to see some parameters in your ecu an pm me when done.
im assuming this is a bad thing? i have a cvt and thats what happens to me.Accelerating in to high of a gear, for the speed, will anger knock control.
Yes for sure, any recently changes in your car?im assuming this is a bad thing? i have a cvt and thats what happens to me.
Yes I installed prl Cai race maf with their tuneYes for sure, any recently changes in your car?
And also I did switch gas I was using shells 92 nitro + or whatever(their prem.) But I never had the ability to watch my parameters I'm using Fremeyers 92...Yes for sure, any recently changes in your car?
