Knock control observations
choo
FL
'17 Hatch Sport 6MT , 1995 240sx
I've noticed if you just free rev above 5000rpm while stationary the knock control will increase a bit from .49 to .52 or .53.
MuffinMcFluffin
Brandon
Elk Grove, CA
I've asked about this a lot and my understanding is that you should consider Hondatas .54 and Ktuner's .49 as equivalent. Knock control is almost better looked at as a trending value, rather than it's value at any given time. For example, 0.60 is not necessarily a bad number, but if you see it go from 0.49 to 0.60 (or similar) under light throttle conditions, you probably have a problem.
I only just now installed TunerView Lite and such.
I was trying to hit 22 PSI on the Phearable tune just a second ago when I was at 0.49 knock control, and it was only hitting 18 PSI. My TunerView eventually "froze" since it lost connection, and when I reconnected the knock control was at 0.64.
I tried to drive light the rest of the way, but couldn't get it back down. I'm reading above this post that I should have hit lighter boosts for longer maybe, but I wasn't aware of the fact.
Anyway, I only have 91 octane and it was about 91 degrees outside as well, go figure (perhaps those two factors are also why I couldn't hit 22 PSI). It never did go down again after driving lightly for ten more minutes, but I'm just wondering if what I was doing was safe or not? Or should I consider something bad is going on under the hood?
Thanks.
Thanks.
91 octane is likely your issue. Splash in a gallon of E85 and fill the remainder up with 91 octane and see how it behaves then.
bluebluemike
Houston, Texas
2019 Civic Sport Sedan MT
I have a 6mt 2019 sport 2.0 NA with the following mods: takeda intake, KTuner base map, rv6 catless downpipe. Before the downpipe my knock control was max .8 After the downpipe install and cruising from Houston to Austin at ~75 at 3k rpm I’m hitting knock control counts of 1.13
What do I do? Is this normal? I’m running lean at 7% LTFT
jdm_mike
Acura Canada
20 FK8 CTR & More
Knock of 1.13 sounds high. I'm still new to this but from what I've read, anything over 0.70 is high and needs some adjustments to be made (different mods, different pump gas, etc)
bluebluemike
Houston, Texas
I’m running 93 exclusively. I’ve never had problems with knock control until the catless downpipe install
bluebluemike
Houston, Texas
V3N0M_VZL4
Mauricio
Miami, Florida
2022 Civic SI
Do some data logs in highway cruising to see some parameters in your ecu an pm me when done.
bluebluemike
Houston, Texas
Christianjwong
Christian
Oregon
Yes for sure, any recently changes in your car?
And also I did switch gas I was using shells 92 nitro + or whatever(their prem.) But I never had the ability to watch my parameters I'm using Fremeyers 92...
You really should always use top tier gas. And if 92 is the most you can find, knock control will elevate a bit more under load and at high rpm. Do you have E85 available? Adding a gallon per tankful would help stabiliize knock control.
