zaidred
- Dec 13, 2018
- 10
- 0
- Canada
- Civic 2017 EX-T
Walking up to the car and putting hand behind the door handle does not unlock the car. However if I use the lock button on the key fob and then use the door handle sensor, then car unlocks perfectly fine. It works as long as the key fob had been used at max under 60 seconds prior to using the door handle sensor. After that its as if the sensor goes to sleep.
Someone describes it better here (image below): https://ca.cargurus.com/Cars/Discussion-t69376_ds754318
My question is: Is anyone aware of any TSB's regarding this issue? Or has someone had this problem before and what was the solution?
I've made an appointment with the dealer in 5 days. I have extended warranty so hopefully this can be covered in that.
