K20c2 retuned
DarkLight
LA
Civic-2016 LX 6MT
I remember when I increased my rev limit the first time. Set it to 7.3k and went out for a test drive.
The first thing I noticed was that power dropped off considerably past 7k, and I got an over-rev code stored, even though I never missed a shift. No CEL either.
I changed it back to 7.1k because that is where the tuning maps for the cam angles stop.
I don’t plan on ever going higher than that again. There’s significantly more power to made on the low end IME.
B3B31011
Edwin
Puerto Rico
2017 Civic LX
With some new higher comp pistons and some head work, and you will get 200hp easy
chuenoona
chuenoona
Saint Paul,MN
2016 Honda Civic LX, 2001 Acura CL Type-S
I agree
Romeoridgee
Honda Dealer Tech.
Rob
Maryland
19 Sport. 17 EX-T. 16 EX-T. 12 Accord EX. 08 LX
Injectors and ?
yansag1982
Yanick
Montréal, Canada
2020 Coupe Sport 6MT
Just got it retuned for a little extra power,
Raised the rev limit from 7000 to 7500rpm so my next gear change will fall closer to vtec at 5500.
mods and dyno info in the video description
WHOOOO WEE!! got yourself a sub :headbang:that's a screamer
First pull 0-60mph in what looks to be a low 7...that's good enough :)
i can't quite reach 60mph on 2nd gear on mine...did not know Ktuner allow for more RPM...i'd like 7000RPM flush myself hehe
fkseven
NA
FK7
That’s really impressive there should be more support for k20c2
chuenoona
chuenoona
Saint Paul,MN
I just retuned my car again and it feels even better ...
main changes are :
Lowered redline from 7500rpm to 7100rpm
Less VTC angle from 6200rpm to redline
More timing added (knock control is great)
Maf scaling adjusted to get short term fuel trims in check
Can’t wait to get my new street tune on dyno to see the difference, according to the butt dyno it feels much peppier through the whole range to redline.
Romeoridgee
Honda Dealer Tech.
Rob
Maryland
main changes are :
Did you do the throttle body coolant delete?
chuenoona
chuenoona
Saint Paul,MN
Do it and you’ll notice a little more pep/throttle response. I did it on mine and could tell the difference, especially with colder weather.
I live in Minnesota not wise to delete that as my throttle plate can stick in winter
Romeoridgee
Honda Dealer Tech.
Rob
Maryland
Install a valve inline with one of the tb coolant hoses and open back up when it gets down to just below freezing. Besides when the engine is warmed up it’s radiating enough heat to prevent the throttle from sticking. What gains were you able to get between ktuners tune and your dyno tune?
chuenoona
chuenoona
Saint Paul,MN
the dyno tune based on his timing and vtc settings were were pretty conservative,
Also he didn’t tune my AFR correctly amd also my short term fuel trims were at +25%
The tuner was not that good I say ...
my street tune is feels better no bias ...
I’m mad I spent $200 bucks on that dyno tune ...
also I got my AFR better and my short term fuel trims closer to 0-10% and the maf scaling adjusted
Chicago
17 civic hb sport
200 for a dyno tune? Thats hella cheap.
I paid 800 for a dyno tune on my SC 9thgen and it ran like shit
