It is tune related, but I've been told that with Hondata the TR3 is difficult because you don't have access to the VE table that needs to be adjusted. I did this myself here and did not have an issue, but I've heard others say they have run into this with the TR3 only, not the TR2. The Volumetric Efficiency of the engine is improved so much with the TR3 and it is outside the range that the factory ECU can manage in the background.getting p2279 code after these were installed, looked for boostleak with no success. tr3 cam with tr3 valve spring set, everything installed to spec. my fuel trims don't look good either can this be a correlation. I'm on a dual injection set up, with r660 on hondata hpfp & 1330cc injectors, custom walbro 450 fuel return kit & stand alone ecu. my long term fuel trims on idle are at .78-.79 with the command always at 1.00. i run full e85 but at the moment the cart has 93 in it, ethanol conent is at 18%...tuner says the code isn't related to the cams but my trims are bad. car idles perfect no bogs, cams were broken in as instructed 2500rpm for 5mins on start up never dropped under 1500rpm. car is running rich, can this be an issue with the calibration ?
It seems like people are having no issue making 400 on pump gas, just as we did easily in testing. I've seen a number of people post their 400hp pump gas stuff with no ethanol, no meth, no special stuff. We made 415 pretty easily on a basic bolt on car and pump gas.so what kind of HP could i get with a prl catless DP and 27one intercooler on 91 OCT gas? sadly i cant get better gas or ethanol in my area
here is a picture of the block, also thanks for the quick send of those piston rings to us. Much appreciated itDouble check that gear stack and make sure its not pushing on the crank. Also double check your clutch stop.
Glad you found it.
what did you mean by checking the gear stack? Like gear stack as in the transmission gear stack or something else?Double check that gear stack and make sure its not pushing on the crank. Also double check your clutch stop.
Glad you found it.
I believe he means to make sure the input shaft gear stack isn't in such a way that it is thusting up against the flywheel/pilot bearing/crankshaft when the transmssion bell housing is bolted up.what did you mean by checking the gear stack? Like gear stack as in the transmission gear stack or something else?
We are working with Jason's car the next couple weeks. We will put more info out when we are finished. The goal is a drop down selection where you can select the cam. We want to verify that there is enough fuel system capacity to make this clearly safe and smooth.Hello Dears
Do you work with hondata for new cam or its just same as tr2 ? I saw jasonpro's post told that you guys working on a new cam
@4piston
