CLnet2014
- Jun 28, 2018
- 3
- 67
- 41
- Montreal
- Honda Civic SI 2018 Coupe
You just said it, 13k miles , just wait for it. I had the same opinion at that time when i was on map 3 , but it didn't take much time to wear out that weak clutch.Disagree w what he said. If you end up needing a clutch, then get it. But i would never buy a clutch first to go to a tsp stg 1 map.
Perhaps it is his driving style or abuse. The clutch should be able to handle spirited driving, but not abuse. I do not and would not recommend anyone go wot in 5-6th gears, unless racing and exhausted 4th gear already. Those gears are for cruising and min gas usage.
There are people running a stock clutch on a flex map, so to each his own. I am on a different platform on e50 but still on oem clutch. Not one issue yet and i go wot many times daily, 13k+ miles so far.
I don't abuse my car , but i do have spirited driving. If it was to cruising around like a grandpa , i wouldn't have bought an SI.
Its a good thing for people still running their stock clutch but it wasn't my experience.
That clutch doesn't like 280lbs of torque. Its a fact.
When i got 18k miles, the clutch slipping was barely noticeable but i just knew it because the power delivery wasn't the same as before. I started to look closely at the rpms and there was weird things going on in WOT. It was not consistent.
But anyway, the only thing i can say at that point is "time will tell" , but keep in mind that someday , the clutch will fail and you'll have to swap.
