Jsracing Hood + Grill enough for heat and pressure venting?
RTC
Bangkok
Fk8
Hi
Anybody has both parts installed and also track? Do they help with both aspects? If I just get the hood, would that be enough?
AlphaDigital
Alex
MW
civic
If youre tuned it wont be enough. You need a radiator too, like PWR.
  • Like
Reactions: RTC
whybuyfwd
Michael
Las Vegas
2021 Boost Blue Honda Civic Type R
hey brother, i tracked with stock hood and cooling mods, only cooling mod i had was hks intercoler and intake, and didn't overheart until the 4th or 5th session in the maryland humidity. i would get a radiator, intercooler, and hood for heavy tracking. also some good brake pads, mine got smoked
RTC
Bangkok
Fk8
I smoked my pads as well with only custom map and HKS intercooler as mods. I want to get a vented hood before considering a track rad.
chadwicke619
Chad
San Diego
CBP 2021 Honda Civic Type R
Its actually my understanding that in this context (lap after lap on track) the intercooler alone actually isn’t really a cooling mod, and in fact exacerbates the engine heat problem.
gxl
Memphis
2018 Civic Type R PMM
In a sense, yes. The consensus is that is will take a little longer to "heatsoak" but when it does, also takes longer to cool down. So the main problem is seems to be keeping it from heatsoaking in the first place or cool it down quickly after the fact. Sounds like a big reason people will do a cooldown lap between each run to cool it down.
  • Like
Reactions: RTC
AlphaDigital
Alex
MW
civic
What sort of power is your car at?
FBO levels on regular pump gas, so not a lot of power. In fact, I requested to keep the car within a safe range for just repeated flogging at the track so its not being juiced for all shes worth right now.
RTC
Bangkok
Fk8
Does FBO include catted DP? Would that be like 370 or 380 peak hp? I want to get a catted DP and a custom tune as well. Like you, I don't want to mess with fuel system since ours cars seem to be unable to deal with overheating issue at current hp level.
Does your car have secondary rad? I heard that it's up there as far as cooling mod goes
AlphaDigital
Alex
MW
civic
Yes, full bolt ons generally includes a downpipe. Mine is the RV6 catted.
The secondary radiator is a game changer for these cars and I do have one.
Honda Civic 10th gen Jsracing Hood + Grill enough for heat and pressure venting? PXL_20230603_185443292
RTC
Bangkok
Fk8
Nice one. It's good to know that secondary rad is worthwhile.
Is that Varis Cooling Bonnet? Does it reduce front lift in addition to cooling? Where do the air from the naca ducts go? Do they run off to the fender vents?
Sleepy
Orange County, CA
‘20 CW
I think in conjunction with the Varis bumper yes it would reduce front lift, and yes it runs to the fender vents.
RTC
Bangkok
Fk8
Why the bumper? The opening is almost the same as oem 2020 model.
If the air really runs off to the vent, does this mean I need to remove the engine bay side cover to make use if this naca ducts? Mine is UK model so it comes with the side covers.
Sleepy
Orange County, CA
‘20 CW
Purely speculation about the bumper as the openings are larger than stock, not just the top opening portion. I also believe the lip is longer and if you add in the canards your looking at more downforce in theory. As for the side covers, yes removal of them would be best. You could always cut the back portion of the covers as well if you would like to maintain them. The air channels for the hood exit closer to where the fender meets the door.
RTC
Bangkok
Fk8
Ah I see. I don't wanna lose Honda sensing as it has saved me a few times before when an NPC changed lanes suddenly. I think you relocate the sensor but dropping 3k on a bumper that is more likely to scrape wouldn't be ideal. I can get canard from Verus engineering but I am still debating if I really need it at this stage yet.
I will probably remove the whole side cover. I am not sure why they existed in the first place. I read through one thread here about if the side fender vents do work or just for show. The OEM hood scoop is functional in theory but not as practical in practice. Something about it already being stamped so they just included it to the car for the sake of it. It then was converted to a rain guide.
I'll probably remove them once I manage to find a used Varis hood which seems virtually impossible lmao.
