fatherpain
- Tom
- Dec 22, 2018
- 27
- 2,205
- 3,799
- SoCal
- Website
- www.civicx.com
- 2018 CTR - CW, 1996 Honda Accord EX coupe
- Build Thread
- Link
- Vehicle Showcase
As metal_driver stated there are (9) of these metal clips with threaded holes to slip onto the tabs of the J’s grill.
Like this. The top (3) tabs do not have corresponding holes on the OEM bumper so these holes have to be drilled... the trick is how do you mark the holes? Had to think on this for awhile and read J’s instructions over and over until I finally understood how.
First, cut (3) small paper squares and use the included bolts to punch holes in them.
Next put some scotch tape on both sides of the squares.
Fasten the (3) squares to the (3) upper tabs using the scotch tape.
Like this.
Now get some double sided tape and do the same thing. Make (3) squares and punch holes.
Peel the backing off one of the sides of the double stick tape, line up the holes and lightly apply to the paper squares, so it’s barely hanging onto the paper squares.
Carefully remove the remaining backing, leaving a sticky tape ready to grab onto the tabs on the Bumper and let go of the paper squares on the J’s grill.
Like this. Double sided tape exposed and ready to grab onto the bumper tabs.
Now line up the (4) upper tabs and insert the grill into the bumper. Press hard at the (3) tabs where the holes need to be marked, then remove the grill.
Woohoo! Success!!! Double sided tape successfully transferred to the bumper marking all (3) holes to drill.
