J's Racing Fk8 Grill
hikaru
Shawn
Marietta
Many peo
I know that the answer for my question was indirectly answered a few pages earlier but would you guys say that the grille is applicable to LX/EX trims? I called VividRacing that sells this grille and it sounded like the guy was reading off of a script as his answer didn't sound confident and replied with "I guess so...". Also, would you guys say that I could interchange the grille to an FK8 if I were to upgrade my trim later down a few years from now? Thanks guys.
Many people have installed type r grill on regular civic, all years all chassises.
fatherpain
Tom
Recommend going directly to J’s Racing USA.
I’ve had nothing but great and fast transactions with Mr. Yasu and he delivers on what he says. The schedule he gives is 100% accurate and he should be able to provide the answer to your question. Vivid not so much.
Yasu / J's Racing USA
1410 E 33rd St
Signal HIll CA 90755
Tel 562-269-0564
E-mail: [email protected]
123sillyboy123
2019 CTR
Front grill is interchangeable.. i have both fk8 and fk7...
But as far as i know.. j's racing grill fitting is random.. u can get good fit or u can get sth that need some modifcation.
Aftermarket knock off j's grill fit even worse
ATM
ATM
FK8
my local body shop charge $180 just for the install.
hikaru
Shawn
Marietta
Honda Civic 10th gen J's Racing Fk8 Grill 94265225-5914-4AEB-9177-028784012311
ATM
ATM
FK8
does anyone know you can use the OEM Honda badge and put it on the is racing grill?
fatherpain
Tom
Yes it will fit any type R Honda front badge. :)
hikaru
Shawn
Marietta
i mean, can I remove the OEM grill and put it on the js racing or do I need to buy js racing badge adapter?
You can remove the emblem, but there is no base for the emblem to sit on if you were to put it on the J's Racing grill.
You need that base or shroud for the emblem to be attached on.
Honda Civic 10th gen J's Racing Fk8 Grill 1614236801197
Honda Civic 10th gen J's Racing Fk8 Grill 1614236857103
Honda Civic 10th gen J's Racing Fk8 Grill 1614236514809
ATM
ATM
FK8
the shop left the bracket in the middle which is behind the mesh. They said if they were to cut that bracket, the grill would have slumped/sagged.
So i'll need that J's racing emblem mount?
Honda Civic 10th gen J's Racing Fk8 Grill 1614344132416
fatherpain
Tom
Pretty certain that plastic vertical bracket will need to be cut off. It will be in the way of the center badge holder.. which is supplied with with a metal support strip.
The center will not sag.. at least mine hasn’t yet ?
Have you seen the installation guide posted?
Can you also post another photo of the entire front of your car with hood closed please?
hikaru
Shawn
Marietta
Yes, the grill will collapse if you cut the center beam in the bumper cover, so keep that and I'll paint it black instead to hide the center beam. Here is how it looks like on another car with the similar grill by keeping the center support beam.
Honda Civic 10th gen J's Racing Fk8 Grill 1614387159806
No, because what @ATM has on his vehicle is yet another knockoff modified version inspired by the J's. There are significant differences.
The original J's Racing grill is twice deeper so the vertical beam will be in its way. You do have to cut the center beam if it's a 100% Chinese copy like this one.
Honda Civic 10th gen J's Racing Fk8 Grill 1614387328757
fatherpain
Tom
Ah thanks for catching that @hikaru didn’t realize it what @ATM has is a replica?
hikaru
Shawn
Marietta
Yeah, this is probably the latest replica that has shallow openings so that the center beam is not required to be removed.
The earlier replica is a 100% copied from the original J"s racing mold. If you look at the comparison pictures above you will notice this latest replica is not as deep as the J's.
