jamesmcintoshjr
- James
- Apr 4, 2018
- 2
- 21
- 63
- Toronto
- 2018 CW CTR
Thought I would share with the forum as this went from a personal project to making these to offer to the community.
JMJR (@jmjr_dsgn) • Instagram photos and videos
Answers to a few common questions-
Why 3d printed and not just 3d print the master and make molds?
- I hate fiberglass. It's heavy, wavy, cracks and is 100 years old. 3D printed kit is impact resistant, lightweight and shaped on both sides for excellent fitment against the existing panels.
What material? - lip and skirt kit is made from PETG which is basically just PET plastic with a modifier to make it easier to 3d print. It paints and finishes fine provided you use a primer meant for plastic.
The door flare finisher and front bumper intakes are made from a 3d print optimized ASA, which is a standard automotive plastic (e.g. your wing mirror caps)
Painted or raw print? - if you're local to me (Toronto, Canada) I've enlisted a bodyshop to partner with to do the finish and paint. Otherwise I can flat pack these in their individual printed parts into a small box for shipping. The only downside to 3d prints is that there really isn't a printer big enough to do this in one shot that's viable for me, not yet anyways so these are printed in pieces (lip is 7 pieces, skirts are 5).
That being said, these are printed with built in dowels so you just panel bond or expoxy, clamp and then a bit of filler and sanding and paint. The parts are designed to have channels at the seams for a bit of filler that makes blending them away easy.
Mounting? - the Lip has 6 attachment brackets designed to use the factory mouting provisions, and the factory screws on the corners of the stock lip, plus a run of double sided tape should be used on the top of the factory lip. Skirts use the 2 screws front and back on the factory skirts plus double sided tape and one extra mounting point in the middle bottom of the stock skirt, for which I supply well nuts and screws. The rear garnish requires making a couple holes on the inside of the wheel well lip, as well as on the underside for which I also supply well nuts.
Avails? - Takes me a little over a week to make 1 kit. I've got one that's spoken for and 1 more that's almost complete.
