1.5T It's that thread again - KTuner vs. Hondata for "no tune"
Which is better for my "no tune" needs
  • Hondata
    Votes: 0 0.0%
  • Total voters
  • Poll closed .
Blitzle
Will
MI, USA
'21 Civic Hatch Sport 6MT, '06 Spec.B, '93 300ZX NA
Already did some research but I had a few questions that on things that weren't clear.
To start, my goal is just to just get rid of this awful rev hang and improve anything related to the throttle response. I also want to change some clutch things but that's unrelated to engine tuning.
What I don't want is any bump in PSI/power. I picked the commuter trim for a reason.
So the questions:
  • For both Ktuner and Hondata, the "stock" tunes that come with are aproximations correct? They aren't truely stock.
  • If I'm buying a used device and it already has certain tunes loaded on it - where do I find the base ones? Either I'm blind or I didn't find anything on the websites. I haven't even checked other map providers talked about in the forum - I assumed all their maps had power bumps.
kefi
oh shit waddup its dat boi
Central Florida
fk8.clinic
2018 Type R
They aren't approximations. Hondata and KTuner essentially take the original calibration file from your ECU and modify it to whatever you want. They aren't playing guessing games and just making something that feels similar, they're simply just not applying any modifications to the file.
The base tunes are within KTuner/Hondata's software itself already, not on the device.
arnoldo
Arnoldo
Jakarta, Indonesia
2019 Honda Civic Hatchback
So the questions:
Stock tunes that come from both platforms are tunes taking from stock ECU so it's not a guesstimated tunes like Kefi mentioned.
Both platforms provide Factory calibration, which is a stock tune comes from ECU, just like the title says.
You can select disable rev hang and play around with any throttle responsiveness according to your preference.
I'd recommend KTuner V1.2 based on your purpose of buying tuning platform and KTuner V1.2 cost less than Hondata Flashpro.
Chaucer
Tacoma, Washington
2020 Civic Si Coupe
I’ve gone with Hondata in the past, for my 8th gen Si and S2000, but on the 1.5L platform Ktuner is king. Even if you plan on sticking with the stock map without rev hang right now (like I did in the past), you might want to pump up the power eventually and Ktuner is the one.
salik990
Salik
Karachi, Pakistan
2016 honda civic 1.5T, 15' Audi A3 1.8T, Toyota Hilux Revo 2017
So the questions:
i m using hondata flashpro, but will suggest for ktuner as you can get more support for e-tuning and custom tune maps.
fenix-silver
Central PA
2019 Si
Can't speak to Hondata, but with the Ktuner software the base maps are just built into the software. You can open them from the menu and then load them to a slot on the Ktuner device.
Yep. It's essentially the same with Hondata. Download the Flashpro Manager program, load a base map to the Flashpro unit and upload to the ECU.
