Is this rust anything to worry about?
Stryder
Monroeville, PA
2019 Golf Alltrack
Finally changed oil myself today rather than taking it to the dealership. While I was under there I snapped a few pics and was wondering if this was anything I needed to worry about? I live in PA, so salt and snow are a thing, but just wanted to know if I should be concerned or get it looked into before it gets any worse. 2017 Civic Si Coupe @ 18,500k mi. I try to keep everything clean, but salt in winter here sucks. Just a little sad seeing a whole different car from below I guess.
Honda Civic 10th gen Is this rust anything to worry about? 20200524_150427
Honda Civic 10th gen Is this rust anything to worry about? 20200524_150412
Honda Civic 10th gen Is this rust anything to worry about? 20200524_150416
Honda Civic 10th gen Is this rust anything to worry about? 20200524_150419
DallasCRX
Dallas
Barrie, ON
1980 Honda GL1100 GoldWing Interstate, 1986 Honda CRX Si, 2009 Honda CRF250X, 2009 Aprilia Shiver, 2010 Nissan Frontier, 2019 Honda Civic Si Coupe
E-Coating on mig welds is always compromised, similar for weld nuts where the weld process removes the galvaneal on the substrate. Nothing serious but you can slow it down by shooting some white lithium grease on those areas when you have cover down during servicing. The service rusting on the shaft won't impact functionality, just appearance.
Giltibo
Gil
Alliston ON Canada
'08 Accord Coupe 5MT. '18 Civic Sport Touring 6MT (Both Red!)
The Company that supplies these subframes does extensive corrosion tests that simulate years and years of regular use, scratching them in a controlled way, and exposing them to jets of highly saline water for days and weeks on end, with drying cycles in between. Honda is very stringent when it comes to these tests.
civicmanic
2016 Civic Touring ; 2020 CR-V Sport(wife)
It's normal and not worrisome at this point. Anybody who sees this as abnormal clearly doesn't live where road salt is used. In Canada it's popular to undercoat the car yearly with products such as rust check, krown or corrosion free. Use of any of those products will help a lot. I am sure there is something similar used in the US.
Giltibo
Gil
Alliston ON Canada
I wouldn't worry about the rust on the axle, but I might be concerned about the rust on the sub frame on a three year old car.
The metal on the control arm is thicker... and part is made by the same company as the subframe, and is made to go through the same tests.
