Is this gap normal?
Driver56
RVA
2018 Civic SI coupe
Is this gap normal?
No. You should be able to simply push it down into place, however your custom center console pieces might be preventing it from locking into place.
Vrait
Vrait
'17 Civic SI
Is it possible for there to be broken clips here? When pushing down, nothing seems to catch it. And my center armrest leather does NOT seem to be interfering.
Vrait
Vrait
'17 Civic SI
Also, I have not had anything done to this part of the dash. Could getting the windshield replaced affected this atall?
Driver56
RVA
2018 Civic SI coupe
It's quite possible there is a broken clip, luckily it's not an expensive part to replace. You can pull straight up on it to remove the bottom section to check if there's a broken clip. Here's a part link if you need a new one:
https://www.hondapartsnow.com/genuine/honda~garn~assy~nh900l~77293-tba-a01za.html
Vrait
Vrait
'17 Civic SI
Ok, thanks I'll take a look sometime soon. Hopefully nothing broke.
Vrait
Vrait
'17 Civic SI
Upon closer inspection this is the lower part and not the upper pieces, so I can't just lift it off to check. I would have to disassemble that whole area.
So I'm just going to have my body shop take a look at it, I'd rather not risk breaking it.
Vrait
Vrait
'17 Civic SI
Can someone show a pic of theirs from the same angle?
JT Si
Place
Car
Mine is fully and securely assembled with no broken clips, loose parts, or rattles. I've taken it apart myself several times for shifter upgrades and other interior work.
Honda Civic 10th gen Is this gap normal? IMG_20191224_074245
Vrait
Vrait
'17 Civic SI
So the gap is the same then? This is the main rattle/creak in my car now that I fixed most of the other ones..
Does it not flex down at all when you push down on it by the cup holder side?
Spacesloth
Wisconsin
2017 Honda Civic SI
That gap is normal, there is nothing clipping it in. I’ve pulled that entire area apart, the section is designed to flex with body movement. Next time you’re driving stick your fingers between the two parts and you can feel it move a little over road imperfections. As far as the creaking are you sure it isn’t the gloss black piece by the shifter, I had an issue with that creaking when it got cold.
Vrait
Vrait
'17 Civic SI
That could be it. Thanks, I'll just live with the creaking then.
