Is my hood misaligned? Or just me...
anckentucky
Kansas City
2016 Honda Civic EX-T Crystal Black Pearl
http://imgur.com/a/FU4dl
My hood seems to be out of alignment with the front end of the car. The gaps between the quarter panel and hood seem fine, but the front of the car and hood seem to be quite a bit off. Added imgur album link and images to thread in case one doesn't load for others.
dick w
Kapaʻa, HI
'16 Civic Sedan Touring, '18 CR-V Touring AWD
My vote is for misaligned.
inv4zn
Vancouver, Canada
'16 Touring
Hood latch may be a bit lower than normal; if that's the case should be an easy fix at dealer. It looked meh until the second last picture - go take it in
sparky79
2016 Honda Civic Touring
Any luck with your hood? I basically have the same issue, hood lower on the driver's side. Debating whether to take it in and have them mess with it (fear of making something worse) or if I will just keep living with it.
Dan198
GTA
2011 BMW 335 xDrive, 2010 Audi Q5, 2014 Porsche Boxster S, 2016 Civic EX
I would make them fix it until they get it right. And take lots of pics so you can prove what's been done.
Gavnzdad
To me it looks like it's the above the grill piece that's off instead of the hood.
Rikee
Ottawa
MDX 2012 - Civic 2016 Touring
My hood was also misaligned when it was delivered and the tech took about 30 seconds to adjust it. There are 2 rubber mount supporting the hood inside the engine bay. He gave a few twist on one side and the alignment is now perfect. Before, it was clearly lower on one side. Yours seems like one of the mount could use a few turn going up. Hope this help.
silverrascal
Texas
2019 Honda Civic EX hatch
I was thinking this very same thing. But I couldn't physically check to know for certain. Thanks.
sparky79
Thanks! I looked a few months ago and just saw the rubber mounts in the middle that do not adjust, but now that I looked again I saw the ones near the edge/fender that you mention. It worked well - and an EASY fix. I would say I got it 90% (which now looks acceptable). Now if I could just figure out how to adjust/align my rear passenger door on the drivers side. It just needs to shut/close about 1-2 millimeters more - it sort of sticks out and is most noticeable near the door handle area and crease line. Not sure if you can adjust the latch mount inwards. I do not think the door hinges will do anything for the issue (again, fear doing anything with the hinges will cause more harm than good). I think there is another thread about the rear passenger doors (in particular the drivers side being more problematic).
Dan198
GTA
I started a thread on the door being misaligned and was told by my dealer there's nothing they can do. Does your door look like mine?
http://www.civicx.com/threads/drivers-side-passenger-door-misaligned.3989/#post-65982
Captain Falcon
Northeast
'16 Civic EX
Could you update us on how you got this fixed? Do you know what exactly was done - and how it was adjusted?
