Is ktuning a Honda Civic 2018 2.0l cvt worth it
V3N0M_VZL4
Mauricio
Miami, Florida
2019 Civic Sport
Aem intake for the k20C will be fine but the K&N short ram will throw off fueling by 20%
I’ve had both ....I had to retune for the K&N for fix my fuel trims
@chuenoona After installing the K&N intake I have seen the knock control altered as well as the fuel consumption, what values can I adjust or what can you recommend to mitigate these effects? thanks in advance.
chuenoona
Saint Paul,MN
2016 Honda Civic LX, 2001 Acura CL Type-S
what are you short term fuel trims ?
+25% at acceleration and cruise ?
or around there ?
V3N0M_VZL4
Mauricio
Miami, Florida
2019 Civic Sport
Around 23 mpg the knock control around 0.74 mostly cruising, a little bit of pulling here and there but not much to be honest, I put gas in costco 93 octane, but can be a bad batch of fuel but I'm not completely sure.
chuenoona
Saint Paul,MN
that’s high knock control, did you modify timing or intake cam timing at all ?
V3N0M_VZL4
Mauricio
Miami, Florida
2019 Civic Sport
Nothing just the intake and the catted downpipe, no modifications in the map.
chuenoona
Saint Paul,MN
what is your fuel trims ? You haven’t told me
and I need those numbers to give you a guideline to adjust the maf values
chuenoona
Saint Paul,MN
your knock control is too high for just the ktune base map … even bad gas wouldn’t trigger that much knock control … it’s strange … when untuned with k&n did not do anything to my knock values …
chuenoona
Saint Paul,MN
Where I can find that info for you? I have the tunerview app in my phone.
It just says
short term fuel trim and long term fuel trim …
I need what it says at
idle
Light acceleration
Steady cruise
I don’t have tunerview but I’m sure it’s there
Or just use the laptop to tell me the values
V3N0M_VZL4
Mauricio
Miami, Florida
2019 Civic Sport
Let me find that information, I will get back to you tomorrow, is a little bit late here in the east coast.
chuenoona
Saint Paul,MN
okay looks like your car is running too lean so the car has had to adjust and add 12% more fuel …
I’m assuming this is at idle ??
can you tell me the short fuel trim reading at cruising as well …
V3N0M_VZL4
Mauricio
Miami, Florida
2019 Civic Sport
This is at iddle, let me find that info for you as well, on other note in regards to the knock is that normal? Maybe is a bad fuel batch for the hacked pipeline here in the east coast?
