Interior plastic cleaning
BringTheCows
Andrew
Floridq
2019 Honda Civic LX hatchback
Hello, I have a 2019 Honda Civic Hatchback LX
I spilled soda on the cup holder; and the whole mechanism that holds it together to allow it to slide back n forth has been tainted with liquid. Before, it used to slide back n forth with just a flick of your pinky, now you have to put all your muscles into it; the glide is just awful.
Honestly, I never wanted to eat or drink in my babe. But it was one of those careless situations where you had a passenger and you forget everything related to the car or yourself because you're focused on them instead. And sh-- happens.
Is there a way to properly clean this? I already have Maguire's interior clean for the plastic interior; I'm going to be cleaning inside and outside of my Civic. She's long overdo for some proper attention and it's about time I get serious with my maintenance that I used to do and haven't done consistently for awhile like I vowed to do. But anyway, I tried water, and that didn't do the trick. It managed to get rid of the Soda stain inside the actual cup holder, but it didn't thoroughly remove anything. I mean it's still VERY much there, but at least it's more likely to be loose/will come off in the future.
I was tempted to just buy a whole new cup holder unit but that's money down the drain that I could apply elsewhere. And I remember when i joined the forums the first time I asked the community for a list of crap I could possibly do for the car and just never had the budget to do so. But turning my life around today with focusing on working & making money, I am finally down the path of getting around to that darn list I've been dreaming about.
Well anyway, I am just focused on cleaning this damn soda stain. Any advice is appreciated. I'll put in some pictures of the cupholder tomorrow when there's sunlight and I better prep for the cleaning she needs. Any advice is appreciated.
TheCanadian
2020 Boost Blue Type R
You mean that plastic part that you can remove? That holds the 2x drinks?
Just take it out of the car (it's removable - pull the little clip and yank it). Bring it inside and rinse it in your sink. Clean the rails it slides in with a wet microfibre and you are done.
BringTheCows
BringTheCows
Andrew
Floridq
That's what i did; but it didn't do anything. i let it soak in water, and used a microfiber to wipe it dry and it still contained the sticky liquid from the drinks. I guess I'll just keep trying that. Thank you
Phy
TN
Honestly sounds like a simple "clean it better" is needed. Especially with sticky liquids.
WF19
Mark
North Las Vegas, NV
2020 Civic Si sedan Aegean Blue Metallic; 2003 Pontiac Vibe (just sold)
Try Dawn and let it soak for a while?
TheCanadian
Make sure you clean the rails. Use a microfibre with your nails using into them, or something like a q-tip. If it's sort of baked in get any car interior cleaner from an auto parts store. You can probably even use a lysol wipe
BringTheCows
BringTheCows
Andrew
Floridq
Thank you friends, I managed to get the all soda stain off entirely; and the cup holder glides smoothly, perhaps even smoother than before!
