Interior Ambient Lighting
angrytoast
Mississippi
2016 Civic EX-L
I haven't really a lot of people talking about interior ambient lighting besides the OEM console lighting that's either stuck on red or blue and requires a stupid amount of work to install for very little effect or the cheap fiber optic lights that really don't look that good, so I thought I'd put this out there.
The little bit of stuff I've seen involves these cheap led lights that run through a bulky fiber optic tube that really doesn't function as advertised. During the day the light isn't really visible and at night, there's bright and dim spots all throughout the trim that just makes the whole thing look cheap and tacky. The kit I ended up running across is an acrylic strip with led lights running through the entire length which gets rid of the "hot spots" people tend to see and allows it to give off evenly distributed light that's visible in direct sunlight. The kits available on amazon are pretty much the same cheap Chinese things that all function pretty similarly and tend to stick around $80-$120 depending on the size of the kit and the seller. I wanted an 18 piece kit which comes with acrylic strips to go across the entire dash and all four doors as well as lights to illuminate the door handles, storage areas, and footwells which ran me about $100.
The installation wasn't complex but it required a bit of time and patience to pull the interior of the car apart and figure out a good way to run the wiring for the lights. I started with the dash which required pulling most of the trim loose but not completely off. I did have to disconnect the A/C controls and pull the head unit down to run the lights and wiring behind it. For the doors I had to pull the interior panels off and push the trim lights into place then drill holes for the lights inside the door handles and storage areas. From what I've seen most kits come with the proper size drill bit so the lights fit snugly and the wires for the acrylic strips in my kit were pretty thin and matched the color of the plastic on the doors so I just ran it behind the edge of the panel to the control box. Each door got its own sub-control box that gets power from the power window motors. Since this was my first time pulling the interior of the car apart and I didn't really know exactly where I wanted to place the lights, the process took me about five and a half hours from start to finish. In my opinion the end result was well worth the work and really adds to the otherwise boring interior of the car. I decided to keep the lights as long as possible to cover as much area as I could but the acrylic strips can be cut to pretty much any length you'd like.
I attached a couple screenshots but here are some videos of the lights during the day and night.
https://www.dropbox.com/scl/fi/ccxs...5453.mp4?dl=0&rlkey=3mghrczpnbvwzz4td3m3qzxwu
https://www.dropbox.com/scl/fi/1s2t...5456.MOV?rlkey=ckcleyx3cvot7epglhqxs26qc&dl=0
Honda Civic 10th gen Interior Ambient Lighting Day 1
Honda Civic 10th gen Interior Ambient Lighting Day 2
Honda Civic 10th gen Interior Ambient Lighting Night
Honda Civic 10th gen Interior Ambient Lighting install
bushfreakz
NJ
'22 SI, '17 FK8
Nice install! Can you share which product you used? Are you able to dim these so it looks more subtle?
BrandonB
Brandon
Huntington, West Virginia
2018 Si Coupe / 2018 SGP Sport Hatch (RIP)
Following
angrytoast
Mississippi
2016 Civic EX-L
Thanks! I ended up going with a brand called HMYC but the dreamcolor kits on Amazon may be a little higher quality. And yes they can be dimmed to the point that they’re barely noticeable. In the videos the lights are set at 100% brightness. In the kit I got, there’s a hard wired button that can control your brightness and cycle through its different modes and there’s also an app that you can download to customize a lot more stuff like the startup animation and all that but it’s not the most user friendly.
https://a.co/d/dWnkt3a
https://www.amazon.com/Dreamcolor-I...dp/B0BR7XV275/ref=psdc_15736351_t1_B0BMZC3D1S
Honda Civic 10th gen Interior Ambient Lighting IMG_5480
NazTehRpR
DE
'19 Civic Sedan Sport, '08 GSXR 600
how much to do my car :bow:
bushfreakz
NJ
'22 SI, '17 FK8
looks good! I'm also now surprised I haven't see anyone try to wrap these around the grills or vent/garnish pieces yet
angrytoast
Mississippi
2016 Civic EX-L
I have the Amazon Dreamcolor ones. They are totally preem!
I like the setup and I kinda wish I would've gone with the dreamcolor. The one I have does have the multicolor like you have it set but its too distracting for me while driving but I have the startup mode set for them to fade in like that.
I'm also thinking about cutting the strips down to the length you have them to just go along with the silver trim on the doors but I'm not sure if it would take away from the effect in person.
Npoore
Nicholas
New Jersey
2020 Civic LX
If you decide to install it yourself, I'm happy to answer any questions you may have.
Hi I know this is a bit old but where did you tap the power in for the passenger power box.
angrytoast
Mississippi
2016 Civic EX-L
sorry for the late reply but on the side of the connector for the window controls there's a green and black wire that are considerably thicker than the rest. Green is positive and black is the ground. that should get you power. I noticed that the car never stops sending power to those wires so the door lock controls always work so that door will stay active for a few seconds longer until the control box detects everything else has shut down and it'll go into a rest mode.
angrytoast
Mississippi
2016 Civic EX-L
Hi, little late. Did you get 6 in 1 to achieve what you did??
I'm pretty sure it was the 18 in one. It came with 6 led strips: one for each door and two for the dash, 8 led bulbs to be drilled into the door handles and storage areas and four led lights to be placed under the footwells. just a heads up if you get the 18 in one make sure you run the wires that light up the floor of the car with plenty of slack otherwise when somebody adjusts their seat, they'll end up ripping the wires. I learned that the hard way and now the light behind the drivers seat is dead.
Robot3RK
United States, California
2019 Honda Civic Hatchback Sport CVT
I don't remember since I bought more than one kit of different sizes between two different cars. If the 6 in 1 dreamcolor version you get comes with 6 strips and the master control box and sub control boxes, than you should be good. However, one of the strips is super short. Better to get more higher than the 6 in 1 if you want similar to the older pictures above.
