Installed the PRL CAI, can’t hear any turbo sounds.
darken
Portland Oregon
Civic Si 2020
Hello, idk if the CAI correctly installed or not. Since all of the parts were used. But I drove it and can’t hear any turbo sounds in first gear but all of the other gears there are turbo sounds like in video. Is this normal?
TheDeliSauce
Jordan
'18 Civic SI
It's likely that there isn't much boost in first gear. You'll really hear the "Blow-off / wooshy" sounds when in second gear or higher, especially in less-open areas like downtown. *fwrrrr-pssshh*
Edgar
New York
2017 Honda Civic Si Sedan
Make sure your actually in boost, you'll mostly hear it when your building boost in a high gear or just flooring it then when u let off you hear that woosh
