Installed flex fuel kit with hondata base map
San Antonio
2017 SI
As post says I just installed kit and I have hondata e85 base map what in the ethanol settings do I need to change to run an e40-e45 blend and get close to the advertised whp/wtq or do I have to run straight e85?
jakabony
Jake
Pittsburgh PA
www.facebook.com
2017 Honda Civic Si, 2019 Honda CR-V EX-L, 2017 Subaru Forester
My mistake, I read that straight E85 isn’t good for our cars, but that you had to run a blend.
2017si_msfiesta
San Antonio
2017 SI
Available Monday Hondata will release the Civic FlexFuel upgrade for the Civic Si.
Using inexpensive ethanol sensors and high ethanol content fuel it is now possible to make significant performance improvements with the supplied calibrations. Not only will your Civic make more torque and power, but it will spool the turbo earlier and faster while operating considerably cooler and smoother.
Unlike manufacturer flex fuel systems, the Hondata Flex Fuel upgrade dynamically adjusts the tuning for peak performance dependent on the ethanol content of the fuel. Just plug in, fill up and go. Gains of 64 hp and 64 lb ft torque over stock are possible for a total of 265 hp and 285 lb-ft torque.
No tuning required. Just plug in, fill up and go.
Here's a quick how to:
https://www.hondata.com/downloads/flex_fuel_upgrade_instructions.pdf
dc2turbo
usa
civic,teg
oh beats me it might do 265whp.
just change to what I said earlier if you want it to run the same IGN as straight E85
I hope you got an aftermarket clutch
2017si_msfiesta
San Antonio
2017 SI
Thank you for your help and I'm running stock clutch but I've been running tsp tune with no issues but I'm not hard on the car either and this and the tsp run about same torque numbers.
j_babsR1
Justin
Illinois
2017 Civic Si, 2004 Yamaha R1
Let me know how your stock clutch handles e85. I’m on stock clutch with full bolt ons on the tsp stage1 tune as well. Thinking about this as well.
PowerPerLiter
Specific Output
Midwest
I would change the ethanol 40 and 60% to 100%
Where do you see it says 265whp for the Si?
I don't think they have a "+9 flex fuel map"
I don't understand this recommendation could you elaborate? Seems like not good advice at all to me. but maybe you know something I don't soooo im curious.
2017si_msfiesta
San Antonio
2017 SI
I wouldn't do this with full bolt ons with stock clutch no way
phood
James
Texas
2018 Honda Civic Si
I'm running the following Hondata calibration base:
Civic SI Turbo MT 2017, tuned +6 PSI with ethanol, FTS enabled, Sport mode start up
I installed the Zietronix ECA-2 kit and to get the ethanol reading from the FlashPro datalog to match the gauge (using a few different blends e40, e65, e75), I used the following settings:
Volts 0.57 @ 0%
Volts 4.90 @ 100%
The car really wakes up on E-blends (I've gone back and forth depending on where I am - E85 is a short [15-20 min] drive in the direction I never go).
I kept it this way until recently I discovered a few options in the, "Mods," tab (along the top of the FlashPro menu) that also made a big difference:
Check > Boost - Optimized turbo response
Check > Throttle - Improved response
Check > Throttle - Disable rev hang
There are a few others in there that should already be checked with this base map.
Design
Southern California
09 MS3, 17 ABM Si Sedan
The flex kit is going to run higher TQ numbers much more easily, and earlier in the power curve, due to the cooling effect. And Hondata strongly recommends a clutch upgrade on their +9 map. Last I checked, the Flex Kit's peak TQ is +5-10 over their +9 base map, and is +20 TQ over the +9 map under 3K RPMs.
I can't speculate how long it will last, only that clutch slip has been encountered at these TQ levels. From Hondata:
+ 9 PSI calibration
The supplied +9 psi calibration (light blue line) is capable of generating 272 lb-ft torque. In our dyno testing we found the stock clutch beginning to slip. The Dynapack dyno is very hard on the drivetrain and is more likely to cause slip than street driving with stock tires. Our road testing to date has shown no clutch slip with the + 9 psi calibration. We recommend using the +6 psi calibration and an upgraded clutch.
2017si_msfiesta
San Antonio
2017 SI
Volts 0.57 @ 0%
Volts 4.90 @ 100%
I've had the tune for almost a week now and love the flex fuel upgrade. I immediately removed the rev hang cause was just hating that. But will toggle the other 2 and try them out thanks for the info. I've had 0 clutch slip so far but as I've said before I'm not wot either.
