Installed Eibach Sportline springs, noticed rear is slightly lower
hpbyhermann
Hermann
Edgewater Maryland
2019 Championship white Type R #25133, 09' Civic SI sedan, black 2013 Boss 302 Laguna Seca, 1993 Mustang Cobra, 2004 Mustang Cobra
After driving the car around for a while I noticed that the rear of the car is ever so slightly lower than the front. I reused all of the factory spring isolators on the top and the bottom when I installed them. After looking for aftermarket isolators and finding none I decided to modify some Mustang Fox body lower control arm urethane spring isolators and that worked perfectly! They were 0.2125" thick and I modified them by cutting off the locating ring so they could sit flush on top of the existing upper isolator. Now the car is sittings level! Now I can get it aligned.
Honda Civic 10th gen Installed Eibach Sportline springs, noticed rear is slightly lower 75B4C68F-F3D1-4042-82D7-D85CA19A961F
Honda Civic 10th gen Installed Eibach Sportline springs, noticed rear is slightly lower CB0A2EAE-9247-4A67-B582-424FCEDF04FF
Honda Civic 10th gen Installed Eibach Sportline springs, noticed rear is slightly lower E0698D38-6661-4223-AB7D-E9C228B6C329
Honda Civic 10th gen Installed Eibach Sportline springs, noticed rear is slightly lower 0D672740-26DF-45C9-AB74-DBD61D0D73D3
Honda Civic 10th gen Installed Eibach Sportline springs, noticed rear is slightly lower A80C6A3E-7BC7-4449-9BF2-3661AF03AFD3
Honda Civic 10th gen Installed Eibach Sportline springs, noticed rear is slightly lower E246A7FB-CBDD-4BE5-8BFB-638F9A26C0B5
Honda Civic 10th gen Installed Eibach Sportline springs, noticed rear is slightly lower EB3CA0E4-CDB5-4286-B4E5-995830F2A261
Honda Civic 10th gen Installed Eibach Sportline springs, noticed rear is slightly lower 46A52905-E897-4043-A3E7-905E9CA8C2F7
Honda Civic 10th gen Installed Eibach Sportline springs, noticed rear is slightly lower 9B9F642F-9922-48AF-A544-3E0EB45B02FB
hpbyhermann
hpbyhermann
Hermann
Edgewater Maryland
I build cars for a living.....lol! "They come like that" doesn't work for some of us....no Jerry rigging anything, I just put a hard urethane isolator above the existing setup....added slightly less than 1/4" of ride height. If you had a car apart in front of you it totally would make sense.:thumbsup: Now the car is totally level.
boosted180sx
torrance, ca
2017 CTR, 2016 ILX
this seems to be the case with eibach stuff. The Pro Kits I had was the same way. It had kind of a reverse raked look to it.
hpbyhermann
hpbyhermann
Hermann
Edgewater Maryland
You're absolutely right! I'm not quite sure why they haven't corrected this issue but I wasn't going to just live with it. Less than 1/4" doesn't sound like much but it totally fixed the issue for me. I'll see how the urethane isolator does long term. If it settles any I'll build a spacer out of 1/4" aluminum plate to replace the urethane. No big deal since it only takes 10-15 minutes to put one in.:headbang:
boosted180sx
torrance, ca
2017 CTR, 2016 ILX
i feel you. I was already going to be replacing them with swifts so i didn't bother to mess with the eibachs. My OCD was driving me nuts though looking at that reversed rake lol.
hpbyhermann
hpbyhermann
Hermann
Edgewater Maryland
Exactly! I literally couldn't stand it! I was actually considering the Swifts but I didn't want a spring with that much rate for a car that for the most part is a daily. Unfortunately the roads around here can also be called minefields because the ridiculous amount of potholes so I need a somewhat supple spring rate to not beat me up too bad!:lol:
boosted180sx
torrance, ca
2017 CTR, 2016 ILX
haha it's not so bad. It is stiffer than the sportlines though.
Sportlines werent out when i got the swifts and idk if i'd wanted to give eibach another try after my experience with the pro kits lol. Good to know you are enjoying it though. At least it looks to be a lot better than the pro kit.
hpbyhermann
hpbyhermann
Hermann
Edgewater Maryland
I honestly love the Eibach Sportlines in every respect EXCEPT for the rear ride height issue. I'm just glad it was a super easy fix!!:headbang::doh: Do you have any pictures of your car with the Pro kit showing the rear sag? I'd like to see that.
boosted180sx
torrance, ca
2017 CTR, 2016 ILX
These are a few that i have. It's not really the best angles but you can see it and it's super noticeable.
Honda Civic 10th gen Installed Eibach Sportline springs, noticed rear is slightly lower 1mf9MgJ
Honda Civic 10th gen Installed Eibach Sportline springs, noticed rear is slightly lower efaUXrh
Honda Civic 10th gen Installed Eibach Sportline springs, noticed rear is slightly lower wuKmkKr
Honda Civic 10th gen Installed Eibach Sportline springs, noticed rear is slightly lower AL8GXoB
here it is with the swift. Much better.
Honda Civic 10th gen Installed Eibach Sportline springs, noticed rear is slightly lower S3NPakE
Honda Civic 10th gen Installed Eibach Sportline springs, noticed rear is slightly lower 1kDEI1U
hpbyhermann
hpbyhermann
Hermann
Edgewater Maryland
Wow.....that's crazy....virtually the same as mine was!!:crazy: No doubt it looks right with the Swifts on it now! Looks great!:beer:
boosted180sx
torrance, ca
2017 CTR, 2016 ILX
yeah crazy right. It was pretty lame. Was pretty disappointed in the rake look along with how the pro kit felt. I don't understand why they have it made like that ...
hpbyhermann
hpbyhermann
Hermann
Edgewater Maryland
I've heard that Pro Kit has some strange handling characteristics due to the rear rate being softer than the front. I've really grown to like the "feel"the of the car with the Sportlines. I'm sure that the larger TE37SL's and RE71R's didn't hurt either.:beer:
jetydosa
ATL
2017 CTR
I could swear I saw on here the Swifts have the same issue.
jetydosa
ATL
2017 CTR
The ProKit rates are exactly 10% stiffer f/r vs stock. :shrug
