SCOPESYS
- Geoff
- Aug 27, 2018
- 68
- 2,505
- 1,550
- MD
- 2018 Honda Civic SI Coupe. . . . . . . .1987 Nissan Maxima Wagon. . . . . . . . . . .1987 Nissan Pulsar NX . . . . . . . . . . . . . . . . . .1987 Nissan Maxima Wagon (2nd Donor Wagon for parts)
My Mishimoto 2016+ Honda Civic 1.5 Turbo Baffled Oil Catch Can arrived earlier this week, and since today was the warmest day we are going to see for the next 2 weeks of sub freezing weather, I decided to install it today.
Easy, 30 minute job ... turned into a 2 hour ordeal .
The catch Can did not come with any install instructions, but that's OK, Mishitomo has a very good Youtube video, showing step by step, how to do the install.
When I first got the can, it was screwed up so tight, it took some doing to get it unscrewed.
Tip: Re-assemble with a little oil on the threads (I used Gear oil, rather than grease).
Makes for a lot smoother tightening, and the added good chance, that it will not seize up, and I will be able to unscrew it in a few 1000 miles, to see how well it is doing.
So, why did it take so long ? Well, the 12mm Socket fell off the socket set wrench, down into the bottom of the engine bay, so I had to put the car up on Ramps, remove the Skid Pan (for the 1st time), to retrieve it.
1st time I had put the Si up on ramps, so that was fun, without the Hand Brake I have on my car .
Thankfully when i dropped the socket, my wife was not around, as the language when I dropped it was not pretty !!
Anyway, a good excuse to get the Skid Plate off, and inspect the location of the Oil Filter, for my next project, which is to fit an Oil Pressure Gauge. Not much room around the oil filter - so that';s going to be a challenge.
I was somewhat surprised to see the amount of white deposits on the aluminum parts of the underside of the engine.
Use to seeing this on Marine engines, but not so much on car engines... thinking maybe a few coats of yellow etch primer might be help .. not heard of anyone doing that though .. maybe overkill.? Comments ???
Another thing that stuck me, as I crawled under the car,
I was under the car , up on 9" ramps. Car Dealers have the Luxury of being able to put cars on a lift, and walk under them. I therefore, now from experience, find it even more inexcusable, that the Dealer "Mechanics ?" are often not securing the Skid Plate back correctly, and either leaving off some of the turn screws, or not fitting them correctly. It's not that difficult !!!
Anyway, having retrieved my 12mm socket, the rest of the install went smoothly, apart from removing the old hose.
One end would not come off, no matter how hard I tried to free it, so rather than damage the fitting, I ended up cutting down the side of the hose on the fitting, and then it just fell off !! Don't need the hose again, and I did not want to risk snapping the plastic barb fitting.
So, now all back together, and meets with the wife's approval... (It's really her car) .. When I told her I wanted to fit the Catch Can, she was hesitant, until I showed her the pretty Blue Hoses (that match the Aegean Blue), and then she was sold !!
