Install American firmware on European head unit
Mingueeel
Miguel
Spain
Honda Civic X Prestige 1.5T 6MT EU
felixlennart
felixlennart
Felix
Germany
2017 Civic Touring Sedan
felixlennart
felixlennart
Felix
Germany
I added but it does not work. Also change <metorcolor> config to "0x04 (Red)" but still not work :)
I took a look into a Type R modelinf.xml (NR-000UH8CEG0-T)
and it had
<MetorColor>0x00</MetorColor>
Maybe you should try 0x00 instead. Or why did you say 0x04 is red?
By the way just out of curiosity, what happens when you change your <Destination> to KG (Germany)? Do you still have the keyless access beep option?
Changing mine from KG to KC didn't affect the available options
Tuan Tran
Tuan
Atlanta
2018 Honda Civic EX-T
and it had
I changed it to 0x04 and it displayed "red" in Vehicle Model Info. I also changed <Destination> to KG and still have keyless access beep option. There might be something else controls this feature or could it be a hardware missing?
felixlennart
felixlennart
Felix
Germany
Then it appears to be fully controlled by the ECU, I dont know if there's a way via HDS
last.of.breed
Daniel
Spain
2018 Civic Hatchback 1.5T CVT
Really interested in this topic since i'd love to be able to enable the option that changes between miles per hour and kilometers per hour, which is something euro civics have disabled, would be nice to compare differences with an UK civic
ManfromRI
RI
17' CW Civic Type R
and it had
I have a 17' USDM Type-R with Honda hack, if your still looking for info to research this.
felixlennart
felixlennart
Felix
Germany
Can you upload your modelinf.xml file here, so we can compare it with the ones from non-Type R cars? I think you can access it with the X-Plore app that comes with Honda Hack
ManfromRI
RI
17' CW Civic Type R
Sorry for the late reply. Yea, do you know where that file is located?. Is it in the root directory? I can prob search for it from within the app.
felixlennart
felixlennart
Felix
Germany
It's in /mnt/data1/com.mitsubishielectric.ada.appservice.unitinfomanager/GroupXYZ/NR-[...]/modelinf.xml
