Infotainment/Head Unit Flashing Green/Blue Sceen
Scathe
Youngstown, Ohio
2016 Civic EX-T
I was actually able to resolve this issue on my own, so I'm not posting this to get advice, but to help others if they experience this issue.
Bought my Civic EX-T preowned, and was having trouble pairing it with my phone. I tried a ton of things to get it to work, and it just wasn't seeing my Galaxy S9+ at all. So I did a hard reboot on the head unit, and that didn't help at all. I decided to try a factory reset instead, and after clicking "ok" through all the warnings about settings and everything being lost, the unit never booted back up. It just kept flashing a green screen; no audio, no bootup screen, it was unresponsive to holding down the power button, etc. Every time I did anything, it would flash solid green 3 times and then go black. I tried starting the car, turning the car off and restarting, same result. For whatever reason it didn't seem to be able to recover from the factory reset.
After Googling the issue, I found 3 suggestions:
  1. Hold the power button for 30 seconds and try to force the unit to hard reboot. This didn't work for me (I tried several times for up to 60 seconds; it would just flash green as soon as I took my finger off the power button).
  2. Hold the power button and brightness button simultaneously for 30 seconds, as this is supposed to be some kind of special hard reboot combination. It didn't work, but interestingly every time I tried this specific combo, the unit would flash a blue screen instead of green.
  3. If none of the above work, they said the unit was supposedly bricked. Take the car to a Honda dealer and have the head unit replaced. This is what many people resorted to in my research. My car isn't under any kind of warranty, so I wasn't about to go that route because it would probably be pretty expensive and time consuming.
Here's what I ended up doing to fix it:
  1. Pop the hood. You should see a a rectangular plastic box on the right side (10th gen Civic). That's the fuse box. Open it.
  2. Inside of the lid you just removed, there's a white plastic clip/tongs looking thing mounted in there. Take it out. There's also a diagram of the fuses which might look a little confusing.
  3. I think fuse #18 is "radio" and #19 is "backup". They are normal small 1-slot fuses in the right side column directly underneath the larger fuses that take up 2-4 slots of space.
  4. Use the tool from step 2 above to remove both of them, and leave them out for about 30 seconds.
  5. Replace #18 and then #19. Make sure they are all the way in. It's hard to get them back in with the tool, since it's more of a fuse puller tool, so you may have to carefully get them started with your fingers and then turn the tool vertically to push them down in.
After doing that, my infotainment system came right back on immediately, and I was able to pair my phone with it just fine this time! Unit was not bricked, and no trip to the dealership needed!
calonzo
New Haven, CT
2016 Honda Civic Touring
Thanks! This worked for me.
Although, after pressing the Start button the first time and after waiting for the unit to reboot, it only showed me a number pad and a blinking cursor with no explanation.
But, I turned the car off and on again, and then it gave me the "Anti-Theft" warning because power was lost. After holding the power button for a few seconds, it is now working normally.
FYI - This all started after replacing an LED headlight, and trying to clear the "Headlight Problem" error on the driver info screen by disconnecting the battery for minutes. It cleared the "Headlight Problem", and replaced it with this issue.
Benzao
Brazil
Civic Touring 1.5
Hi, Did you make it with the Head Unit power on or off (dashboard on or off)? And did you replace in fact the fuses or just release and insert the same? Thank you very much!
DigitalJosh
Josue
www.facebook.com
2016 Honda Civic EX
Hi Scathe. Thanks for posting about this. I've tried the suggested steps and have not yet been able to get it working. Before giving up, I'm finally disconnecting the battery for 30 minutes before trying all your suggested steps once more.
Was the car on, off, or in accessory mode while you performed the steps?
