Incorrect LED Installation??
buttsbunny
Peter
2018 CIVIC LX
Hello everyone! I had installed these a while back and was gonna ask but forgot about it until know. After installing my LEDs, there is this line that goes through the actual light. Did I improperly install these? And if so, what is the method to cure this. Sometimes I’m not even sure my lights are on at night time. Thank you
Honda Civic 10th gen Incorrect LED Installation?? FF610719-DF23-4BA0-B4A8-32C5F74716FC
Honda Civic 10th gen Incorrect LED Installation?? 558BA93F-F13F-486F-82F9-435F113F82F0
Shankmeyster
AZ
23 Si
What LEDs are they? I have the Morimoto 2 Stroke 2.0's and I had to make sure and line them so the output goes to the sides like a regular bulb would so the light output looked normal. Line should be vertical.
buttsbunny
Peter
2018 CIVIC LX
These are hikari lights. Are they not vertical right now? I’m not sure I understand what you mean by lining them up tbh :/
The LED chips should be positioned at 3 o'clock and 9 o'clock.
julianzh
Quincy
2016 Civic EX-t, 2019 GTI Autobahn DSG
It's normal. On the halogen stock bulb, you can see a small "H" in the center of the light output.
Donkeyhotay123
HB
2019 Civic Hatch
They do that because the LEDs are mounted on opposite sides, sandwiching a flat column. The line you see is the empty spot on the middle of the column.
Its why the beam for each bulb being projected isn't one straight line, but two layered over eachother
