Ann Empire
I just bought a car from the US to Africa (Ghana) but it came with these warning signs. Can someone help fix it, please?
Yes, we have one in GhanaIs there a Honda dealership in your area?
The battery was plugged while it was transported. And Yes, i have driven it to several workshops here but to no avail.Was the battery unplugged while it was being transported? Have you driven it at all since getting it? If so, how far?
Those typically show up after disconnect your battery and reconnect. You have to drive it for a bit to get the system to gets it's bearings and the warning signs will go away. I had the same issue when I disconnected my battery. I even had to pull over and turned the car off for awhile then restart clear some errors that wouldn't go away after my initial drive. All is good after that. Hope that helps.The battery was plugged while it was transported. And Yes, i have driven it to several workshops here but to no avail.
Alright will try this step.Those typically show up after disconnect your battery and reconnect. You have to drive it for a bit to get the system to gets it's bearings and the warning signs will go away. I had the same issue when I disconnected my battery. I even had to pull over and turned the car off for awhile then restart clear some errors that wouldn't go away after my initial drive. All is good after that. Hope that helps.
