i just cant heel toe in this car
Crakzor
Mathanael
DFW
2014 Chevy Cruze, 2020 Civic Si
makes me feel amateurish but its just impossible in this car. Also my last car shifted so much smoother maybe i just have to get used to the car. It's a 2020
Honda_RacerX
2019 Si
youll be able to do it eventually. i couldnt at first either cause the gas and brake pedals are so far apart both side to side and forward and back.
after owning the car for over a year i can do it pretty easily now.
Honda_RacerX
2019 Si
The pedal spacing is terrible stock. Its not your fault. I suggest the acuity pedal spacer to fix your issue.
i tried the acuity spacer and it made it worse for me. it makes the gas pedals protrude too far towards the drive and as a result made my ankle hurt.
i did adjust the brake pedal back a little but though only like a cm but it still helped.
Maroco
Martin
Tulsa Oklahoma
2012 Honda civic lx 2020 civic si
Just tossing out ideas. Gotta find the one that works for you. There are 2 or 3 different brands offering relocation brackets for our gas pedals. Id shop around and see which ,if any, seem like a viable solution for you!
zhendexing
Dee
Chicago
2018 civic si coupe
What about Position C?
I personally use location C as well and it’s perfect.
JT Si
Place
Car
I've been using location C and it's an excellent placement for ergonomics and driving comfort for me, but it didn't make heel toe any easier.
I may try A or B and see if it improves.
Design
Southern California
09 MS3, 17 ABM Si Sedan
The problem IMHO is that Honda engineered a lot of travel into the brake pedal. During corner entry under hard braking, it seems to be fine. But under any other scenario, the brake pedal protrudes just far enough to make heel/toe feel awkward.
Maroco
Martin
Tulsa Oklahoma
Mine is opposite. There is basically no travel in my brake pedal. I feel like id be locking up the brakes if i pushed any harder than a few cm. If there was more travel i feel like it would be easier to get my foot level with the gas more making heel toe easier.
Yonder
Miguel
San Diego
'18 Civic Si
cammyfive
Ed
Atlanta, GA
2021 Toyota Tacoma TRD Off-Road 6MT
I'm almost embarrassed to say that I tried this the first day driving my car home and completely missed the gas pedal with my heel. I'm 5'10" and the pedal placement is far from ideal for heel-toe, I've been doing it in every manual I've owned from 20+ years and this is the hardest one to do naturally for me.
pinhead66
Bay Area, CA
Get the Acuity spacer... not ideal for my needs but much better than stock. I use position B, didnt like C. As satisfying as doing a heel toe downshift correctly yourself is I still wish the Si had auto downshift revmatch like the CTR does.
fenix-silver
Central PA
2019 Si
Consider the Perrin relocation bracket as well. It requires trimming a mounting bolt, but it might provide a better heel-toe position than the Acuity.
Chief lazy leaf
Joshua
Grand terrace
2018 civic SI, 2001 mr2 spyder, 1982 Toyota coroll
I can get it under hard breaking no problem. Dont need it for anything else really. It is a pain at first. Ended up not buying the pedal spacer since I seen so many people not like it.
