TheShadow
- Ben
- Apr 19, 2018
- 20
- 238
- 343
- Iowa
- 2017 FK8 Type R #00561, 2012 Civic Si, 2000 Civic CX Hatchback
Hey guys - I wanted to share that I posted up an installation video for the Hybrid Racing short shifter into my FK8. This is a great mod; the shifter feels really solid and smooth. I honestly wouldn't have known how much free play was actually in the stock setup without swapping to this shifter. I also really like that this kit DOES NOT require any base bushings. Which is a little confusing, since Hybrid Racing does actually supply 10th gen Civic shifter base bushings. They just designed this shifter to not need them (instead it hard bolts right into the chassis under the center console.) You would only want those shifter base bushings if you were adding them to the stock shifter.
The install is really simple (albeit a little tedious with removing interior panels and wire retention clips) and is able to be completed with the least amount of tools I have used compared to any other modification to date. You only really need a Phillips and flat head screwdriver, maybe 1 or 2 plastic pry tools, a 5 mm Allen wrench, and a basic socket set (I believe I only used the 10 mm like always.) If you decide to swap out the centering spring to the less stiff one, Hybrid Racing does recommend a specific torque on their screws but since that step is optional I wouldn't say a torque wrench is required here.
I only have 2 other remarks to make on this shifter:
1- Give yourself a few days to get used to the change in gate spacing and throw. Everything felt a little stiff the few days and I found myself missing gears like an amateur. Once you get the rhythm though it feels amazing.
2- Make sure you angle the dogleg for the shift knob in the appropriate range. Hybrid Racing does specify a range that will work, and I thought I was within that, but I think I initially had it rotated too far clockwise around the main shifter rod. I say this because I had a little difficulty going into reverse - not enough that it was immediately apparent that my issue was this adjustment though. It wasn't until I put the shifter into reverse and stuck my finger between the rod and the edge of the shift boot trim to feel how close it really was. So my advice is before you button everything back up, snap the shift boot trim into the console and run through the gears to make sure you have clearance on the left when in gears 1 and 2, and clearance on the right when in reverse. Actually stick your finger down and feel the clearance - shoot for a fingers width at least.
For reference Hybrid Racing does supply set of text instructions that you can print off and have during your install as well, linked here:
https://guides.hybrid-racing.com/Gu...Civic+Short+Shifter+Install+Guide/245?lang=en
