zeppelin2
- May 7, 2019
- 13
- 70
- 32
- Canada
- Honda Civic Type R
I have the full Hybrid Racing shifter for my Type R and when it's set to the longest throw (setting 1), shifting into the odd gears (1/3/5) has the shift lever make contact with the base. In other words, the shifter makes metal-on-metal contact every time it goes into odd gears. It results in a thud that can both be felt and heard at the end of the shift and is very unpleasant. It's wearing down the paint as can be seen here:
I sent my shifter in to Hybrid Racing and they tested it out and confirmed the shifter is making contact with the base every time it shifts into gears 1/3/5. However, they're dismissing it as "normal" and that it's "functioning correctly" as the gears are fully engaging. I'm amazed at how they don't consider this a design flaw.
It doesn't have this problem when shifting into even gears (2/4/6) at the longest throw setting, and it's not a problem in any gear at the shortest throw (setting 2). It's as if they didn't design enough extra space after the gear is fully engaged to allow for some extra play.
Can anyone with this shifter comment? Do you have yours set to the longest throw and does the shifter block the shifting in odd gears?
