Hub spacer recommendations
MJ112588
Mark
Elk Grove Village, IL
2006 civic SI, 2016 Civic EX, 2014 Ford Focus SE
Quick question on anyone's previous experience with spacers for the 10th gen civic. I have a 2006 civic SI with winter Blizzak tires mounted to the OEM wheels that I want to use on my new 10th gen since the SI is a summer car only. I got the rear wheels mounted up but the rim hits the calipers on the front so I am planning on getting 5mm spacers to resolve the clearance issue. It looks like the bore size on both these civics are the same at 64.1mm I believe, so that is convenient as no centric rings are needed then.
Does anyone have a recommendation on which brand spacers to get or where I should purchase them from? I always prefer getting quality stuff even if it costs more so if any of you are running a set now that work great please let me know where you got them from.
Thanks!
hfpdohc
Hatch 2017 M/T
i know that ichiba v2 spacers where the bomb for the 8th gen civic...dont know but it will probably fit on the 10th geen....but not in 5mm
15mm and up hubcentric
