Hub centric aftermarket rims
earlmg
Matthew
Baton Rouge
Civic Hatchback Sport
Hello, I recently purchased 4 ESR CS12’s with a hub centric of 72.56. I have a Civic Hatch Sport and was wondering if I needed to buy a hub centric or if it was fine just installing without it. This is my first time with aftermarket rims so please be patient with me.
panas
Panos
Greece
Honda Civic 2019 sedan, non-Si
You DEFINITELY need to buy hub rings to fill the gap from 72,56mm to 64,1mm (civic hub centre). They are not expensive at all and many aftermarket wheels come with those if you order them specifically for your car.. You'll probably need lug nuts as well as it is almost certain that the OEM ones won't fit your new rims..
arpypat
Civic
Yes, like @panos mentioned, you should get 72.56 -> 64.1 mm hub centric rings. Plastic ones are fine and you can find them on Amazon, eBay, etc.
You must buy aftermarket lug nuts with a cone seat. The OEM lug nuts are ball seat, so they are incompatible with aftermarket wheels.
ChefRyeSi
Ryan
Rhode Island
2018 Civic Si Sedan / 04’ CRV EX 5MT
For the real answer, you TECHNICALLY don’t need them. I rode my wheels for some time before buying the rings and nothing happens. It’s harsh on the wheel studs as they are the contact points without the proper centric ring. If you don’t hit potholes you’re fine. But as stated, they’re like $20 and are made to spec to fit. Well worth it
earlmg
earlmg
Matthew
Baton Rouge
Gotcha, do you know the size of the lug nuts I need to buy?
arpypat
Civic
M12x1.5 and make sure they are conical/tapered/acorn style. Many different names for the same thing lol
OEM Honda lugs are ball seat, so you need 60° conical ones with aftermarket wheels.
earlmg
earlmg
Matthew
Baton Rouge
dstix747
Warner Robins, GA
2020 Civic Hatchback Sport Touring
This is correct. The cone seated lugs will act to center the wheel. I still put rings on but it was just extra piece of mind. I knew I didn't NEED them.
