use a prey tool a flat plastic tool to pry off the window controls,its held in by clips. once unclipped carefully unplug the harness from the control. theres 1 screw there you need to remove. from there if you reach around the bottom near the speaker area, the plastic panel slightly sticks out past the area it meets the door. you can pull on that, and with a good tug that should release the clips from the door. there are several clips so you need to work your way up the panel. once all the clips are released you should lift up and away from the door. repeat for all doorsI have a 2017 hatchback and would like to upgrade the speakers. How would I remove the door panel? Thanks!
Thanks!use a prey tool a flat plastic tool to pry off the window controls,its held in by clips. once unclipped carefully unplug the harness from the control. theres 1 screw there you need to remove. from there if you reach around the bottom near the speaker area, the plastic panel slightly sticks out past the area it meets the door. you can pull on that, and with a good tug that should release the clips from the door. there are several clips so you need to work your way up the panel. once all the clips are released you should lift up and away from the door. repeat for all doors
