How to disable fuel injectors for a compression test
Tima5200
Tim
PA
21 civic type R
Hello,
Trying to do a compression test on a FK8, the car won't crank with the 2 FI fuses pulled, and definetly sprayed fuel with them in so stopped before potentially causing damage. How do you get the car to crank with out the injectors working?
Thank you in advance
  • Like
Reactions: DKL
xSenbon
Atlanta, GA
2021 CTR | 2007 350z
Generally there is a clear flood mode in every car so correct me if I’m wrong for the type r but put your fuses back in and hold down the gas pedal to the floor and try to crank. With the gas pedal to the floor, it activates clear flood mode (which is if your cylinders are flooded with gas or whatever) and will crank the engine with the injectors disabled. I have not tried it with the type r but 95% of all the cars I’ve done it on is the same method so unless for some reason there is a different method of activation this is how you should do it.
Mcclaughry95
500hp is the goal.
Ryan
Central, Pa
18 Civic Si
Why not turn the engine by hand from like the accessory belt pulley? Idk tho haven't done it on this car yet.
BrokeCTROwner
Mario
2019 Type R, 1999 K20 Integra
This does not work I tried it when I first got my type r as I did this a lot with my previous sti. The type r just turns on then revs to 3000
Tima5200
Tim
PA
21 civic type R
I tried to hold down the gas in accessory mode and it still sprayed fuel so I stopped after it cracked twice to not flood it.
Tuxedo
Bay Area
2018 Civic Type R
Tried this before, it doesnt work the engine will start and rev like up. Remove fuel pump fuse
DKL
Maine
'18 Challenger Hellcat. '06 Z4 '97 Supra '18 CTR
I tried pulling the fuel pump fuses, car won't crank.
Tima5200
Tim
PA
21 civic type R
Yup been there twice. I gave up, for now. Don't understand why they had to make it so complicated.
shadow
Philippines
I have an idea of how to get it cranking without starting hopefully. Try this at your own risk.
With engine off and transmission in neutral, use a remote starter switch.
https://www.amazon.com/s?k=remote+starter+switch+for+cars&i=automotive&crid=1O669AM90QK00&sprefix=remote+starter+switch,automotive,375&ref=nb_sb_ss_ts-doa-p_2_21
That will crank the engine, but since everything is off, nothing else except the starter should energize.
Here is a diagram of a starter:
Honda Civic 10th gen How to disable fuel injectors for a compression test 1616204819898
B is connected directly to the car's battery (+) with a fat cable and S is connected to the ignition switch. To energize the starter, the ignition switch provides +12V to the S terminal.
The remote starter switch is connected to B and S. If you short B and S, the starter will crank.
