samuelmei2012
My LCD display will not turn on at all. EVen when my vehicle is started.
Any help?!
Any help?!
Have you accidentally hit the brightness button on the top (physical button)? It has an "off" setting.My LCD display will not turn on at all. EVen when my vehicle is started.
Try a hard boot by pulling the connection for the battery off for about 30 seconds. Also double check for blown fuse or loose fuse connection. Check the amp fuse and radio fuse. Your case it may just be the radio fuse.I cant even reboot it since the display isn't even powered
Got my pdf mixed up, that was for our pilot. Thanks for catching that I updated with the correct page.Is that even a '16 Civic OM? Mine doesn't go to page 628? And its fuses and fuse locations look nothing like this.
Pressing it will toggle between bright, not so bright and off.I pressed it and it did nothing. The display was working fine last night; up until this morning when i started her up.
