How much oil should I add
Dairm
戴瑞敏
China nanjing
Civic
Hello, I'm a new comer. I just used the stage 2 program of ktuner for my 2019 MT Civic. How much oil do I need to add? The dealer told me that I should add 4 liters, but I'm not sure
Dairm
Dairm
戴瑞敏
China nanjing
Civic
Can someone answer my question about engine oil
Jason Baker
Jason
Lake George, NY
2018 Civic Si Coupe
I don’t think most of us follow what you are asking?
What do you mean by stage 2 ? Are you running ethanol?
The dealer told you to add 4 liters of oil? Why?
Dairm
Dairm
戴瑞敏
China nanjing
Civic
I'm sorry, it should be ktuner base map 2
He asked me to add 4 liters of engine oil, saying that it could better protect the engine. Is that true?
Jason Baker
Jason
Lake George, NY
2018 Civic Si Coupe
So I recall the 1.5 liter taking 4.7 quarts of oil.
1 liter is about 1.1 quarts so ……
To be clear, the dealer told you 4 more liters of oil because you are using base map 2?
I’m curious, what “dealer” gave you a suggestion to add oil when using a “tune” that most dealers won’t likely know much about and likely failed to mention anything about voiding your warranty once using said tune?
He suggested adding 4 more liters? For a total of 8 liters? Please clarify.
Dairm
Dairm
戴瑞敏
China nanjing
Civic
For a total of 4 liters, Yes, he said so because I used the base map 2, This dealer is “ktuner China”
He said that the base map 2 is safe, so there is no need to worry about the warranty
Jason Baker
Jason
Lake George, NY
2018 Civic Si Coupe
You guys roll dirty.
So yeah assuming you are referring g to the 1.5 liter engine, then I am sure 4.7 quarts will do.
I’d check your owners manual first ! I’m not sure what exactly Honda runs in China for an engine.
Good Luck
Dairm
Dairm
戴瑞敏
China nanjing
Civic
Good Luck
I mean l15b8 ,
I will check my owners manual, thanks
Ap1 George
George
Las Vegas, Nevada
2017 SGP Civic Sport Hatch 6MT
The 1.5t engine calls for 3.7 quarts or 3.5 liters when doing an oil and filter change. Normally I fill with 4 quarts or 3.78 liters.
CMarks
Connor
NJ
2018 Honda Civic Hatchback EX
Why would you be adding oil for a tune? Are you doing a oil change? And a oil filter? The car will hold 3.7 quarts for full oil and filter change. If thats what your wondering but it seems nobody even knows what your trying to ask.
Dairm
Dairm
戴瑞敏
China nanjing
Civic
The ktuner dealer told me that I should add 4 liters of engine oil, otherwise my engine would be damaged. I don't know whether it is necessary to add so much engine oil. That's all
I can't speak English. I use translation software to communicate with you. It may be difficult to understand the description. I'm sorry
markon
Greece
CRX-B16A / EK4 VTi sedan B18C/ FK7 1.5T EUDM
there is no way or any case that you will need to add an extra 4ltr of oil
DO NOT DO THAT
no matter what tune you use or what tuner you have DO NOT ADD EXTRA OIL
the only thing you may need to do is change your engine oil a little more often and that it's it
your engine must have at all times 3.5~4ltrs of oil none more for sure and of course not less
Dairm
Dairm
戴瑞敏
China nanjing
Civic
DO NOT DO THAT
the only thing you may need to do is change your engine a little more often and that it's it
Thank you very much. I understand
REBELXSi
Señor Member
Anything over 4 quarts is going to cause problems. Add however much you need to hit the top mark on the dip stick
