rwsmith123
- Richard
- Jan 24, 2018
- 12
- 357
- 309
- Raleigh, NC
- 2019 Honda Civic Sport Touring
In particular the ones that don't have the gap in the sides, part number 91505-TM8-003. If the clip is easily accessible they can be removed by punting a flat head screw driver on each side and pry both sides at the same time. However when removing the fake vent cover to replace the fog light or to do a horn upgrade there is one of these pins in the corner that is difficult to reach and really hard to remove using 2 screw drivers. I bought a push pin removal tool on amazon but the tips were to wide to easily fit into the gap between the center pin and outside of the pin.
Honda sells a tool for about 30 bucks but I couldn't find any good images of it so I didn't know if it would be much easier than the generic one that didn't work too well.
Solution, design and 3d print my own tool. The gap is only 1.5mm wide so if I printed a traditional type of push pin pliers the points would be to flexible and too fragile so had to come up with a different design. The design I came up with was a clip that presses over the center pin and locks into place:
Then a collar slides over the clip to keep to it locked into place:
And then for the final little bit it screws down and the edge of the collar presses on the outside ring of the push pin which will then force the center pin to pop out.
Here's a little demo:
