How do you guys do a 'CLEAN' oil change?
NapalmEnema
I know some run a fumito valve but I've read some things about those that makes me paranoid to run one - so those that do it as it sits - in their garage - how do you not get oil jetting everywhere under the car when you release the drain bolt?
I was armed with a funnel this time as well and it still got me it's like high pressure?
I took the filter out first - caught the drippings - was off to a banging start.
Then the oil drainbolt - ARGGH
Now I have a big mess to clean after I finish. Any tips?
Byron Sexton
DMV
2006 Mazdaspeed6, 2020 Civic Type R SGP #36784
It's what you gonna get doing your own oil change lol
Mcclaughry95
500hp is the goal.
Ryan
Central, Pa
18 Civic Si
Oil in these is like water. Not much you can do to limit the splash. But I've had no issues doing my own.
RedGiant217
Indiana
2001 Honda Accord
Yeah, the oil is so thin it pretty much just shoots out. I position drain pan pretty far back to catch the initial flow and then move it a little toward the end.
Not sure how much difference it really makes, but I do drain plug first; then filter. If you leave oil cap and filter in place, the oil may flow out just a tad slower.
The Vyzitor
MityVac fluid evacuator.
If you get it in to the oil pan just right, it’ll drain it almost completely. You can put it up on stands after and pull the drain plug if you like, only about a shot glass worth more comes out over a few minutes of dripping.
Honda Civic 10th gen How do you guys do a 'CLEAN' oil change? F0C1CAF5-B45A-42A4-8464-2B8A61D5C837
NapalmEnema
NapalmEnema
This looks badass!
NapalmEnema
NapalmEnema
Yeah but man the dealership techs and my car? All kinds of things can go wrong. It's not hard to do, just a bit messy so was looking for options.
NapalmEnema
NapalmEnema
What's your setup then? What do you use to catch the oil? I have some flat deal I got at an auto parts store but it's short so catching is hit or miss depend on where it shoots out to lol.
jtrader
OH
Put on latex gloves. Spin the drain bolt until you know it's off the threads, but keep it pushed into the hole. Oil will start slowly dripping onto your gloved hand. Pull the plug as quickly as you can back away from the hole. Oil will go cleanly into the drain pan, which as @RedGiant217 said you have pushed farther away to catch the stronger intial flow, then slowly move it closer as it turns to a drip.
Have some paper towels handy to wipe your hand. I can usually do it with zero drops on the floor about 75% of the time. The other 25%, I get careless and drip a few drops. No biggie, paper towel wipes it up. Good luck!
bcrichster
Wes
FL
I use an 18" x 26" commercial dough tray I use to drain fluids.. it's like 3.5" high and so wide, hold many quarts of fluid. Well worth the $25
Centripetal
Boston, MA
2006 RSX Type S, 2017 Civic Type R
Honda Civic 10th gen How do you guys do a 'CLEAN' oil change? 7B14A65A-4E4E-4715-B92F-09CEF5F9B148
I remember to open the hood and slightly open the oil cap. Then raise it up. Then put the 8 gallon 18” oil drain under it.
The key is how much open the oil cap. Keep it on and it’s going to juice all over the place. Take it all the way off it’s going to shoot.
NapalmEnema
NapalmEnema
I take the filter off first maybe that's what gives it 4000 PSi - I'll try a different method - thanks for the tips all
fatherpain
Tom
Honda Civic 10th gen How do you guys do a 'CLEAN' oil change? 270210C7-1C6E-4BA9-B655-A27D8FC31565
Highly recommend a Fumoto F106 drain valve. Gamechanger. Easy and clean. Have had (5) track days and about 25000 miles on it. No leaks.
Honda Civic 10th gen How do you guys do a 'CLEAN' oil change? 16CC8874-D4E9-41A3-B7A5-9B98177B5E0A
Use a ziplock plastic bag to remove the oil filter and catch the residual oil.
Honda Civic 10th gen How do you guys do a 'CLEAN' oil change? E58668AC-6F62-4BD3-8B11-FB062CCAA913
I drain oil and filter residual directly to this style of bucket. Not going to use catch pans anymore.
Honda Civic 10th gen How do you guys do a 'CLEAN' oil change? 34C7F14C-AC18-4A00-B55A-DDEB53FF6A1A
Because the bucket has a sealable lid. Can then transport it to the auto parts store and dump it :)
