How do Swift Springs + 18 inch wheels feel?
dcxz19
David
2020 Type-R PMM
Hello CivicX,
Just purchased 18x9.5 wheels with 265/35 tires and am planning to pair this with Swift springs.
Can anyone chime in on how they feel? I know that Swift springs have a higher spring rate compared to other brands (Spoon, Eibach, etc)
I'm hoping that downsizing to a smaller wheel + thicker/meatier tires will "balance" out the increased spring rates.
WhiskeyTango
Matthew
Milwaukee
2019 Civic Type R
Offset is critical to know whether you are going to rub with a 265
Ride quality is improved, and with the right tire, handling is as good, or even better than stock. Some people might argue torque steer, but its negligible IMO.
OrchidFc3
Holly
New Brunswick Canada
2017 Civic Type R, 1996 ITR, 1992 SI
I am running that exact setup and it's amazing! Handling is great and not so rough with the 18s.
Honda Civic 10th gen How do Swift Springs + 18 inch wheels feel? DSC_7311.JPG
Honda Civic 10th gen How do Swift Springs + 18 inch wheels feel? DSC_7347.JPG
dcxz19
David
2020 Type-R PMM
My bad, the offset I'm going to be running is +38.
dcxz19
David
2020 Type-R PMM
Awesome! I'm actually going to be running the same exact specs as you! I got the 57DRs instead haha. Glad you hear that the ride quality is improved! Part of the reason why I ask is due to my paranoia of hitting pot holes on the stock wheel setup.
Would you say the ride is more or less stiff compared to stock?
WhiskeyTango
Matthew
Milwaukee
2019 Civic Type R
I'm running 57DR's same spec and its my understanding that 265's will rub with a +38 offset. Hence why I run a 255.
Coqui
Ramon
ST LOUIS, IL
'20 Boost Blue
I'm running 18x9.5 38offset w 265/35s on swift. You'll rub during hard dips on tab w plastic screw by sidemarkers. Easily remove screw, then bend the thin metal tab in, pinching fender liner w it. Tab bends with hand pressure. No rubbing since.
Honda Civic 10th gen How do Swift Springs + 18 inch wheels feel? IMG_20201119_110323_273
Ultimateone
Boston
2021 STI
Damn your fitment looks pretty close to just 1 finger, Swifts definitely seem to lower the most.
dcxz19
David
2020 Type-R PMM
Thanks for the tip! Going to have to do this...
HelloImKevin
Kevin
Rowland Hgts
2020 Civic Type R CW
Im Running 18x9.5+35 on 255/35 Michelin Ps4 on Swifts. i had my rears cut and fronts rolled. If you need a fender worker i can Rec one to you if you live in Socal Best in the Business.
BoozerC22
WA
2020 Civic Type R PMM
Would you need rear camber arms for lowering springs?
