Hi there, can you fit 2 big travel bags or suitcases into the fc sedans trunk? I'm curious about the size of the trunk as I now drive a 2011 EU civic FK hatch and want to buy the sedan now.
The trunk seems very deep but not wide enough?
it is a big trunk, for sure wider than your car's and much longer, but the height and entrance is a bit limited by the trunk lid. You can still fold the rear seats to increase space when you need so I never had problems with suitcases but once i couldn't fit a washmashine, it was the only item i had to give up moving...
Thanks for your reply!
I can now fit 4 winter tires 225/40/18 without folding the seats. They fit side by side. The arrangement should be different now, but will fit also.
I am just asking because I will have to drive my parents to the airport from time to time, now there is now problem.
Here in Europe people buy wagons over sedans, but that's no option for me
i think you can't fit 4 tires because the height is not enough to put them vertical, probably you will have to fold the seat. Normal luggage on the other hand can use the space much better so you will be able to carry more than with your current car.
